[GRASS-dev] [GRASS GIS] #3130: r.out.gdal: add alpha channel support
trac at osgeo.org
Fri Aug 12 12:02:12 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-releasebranch72
Resolution: | Keywords: r.out.gdal
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:2 neteler]:
> Replying to [comment:1 mmetz]:
> > Replying to [ticket:3130 neteler]:
> > According to Landsat metadat, 0 is not a valid data value, valid range
is 1 - 255. Also, r.info -r shows that 0 is not present, therefore 0 can
be used for nodata.
> Well, this was just intended as simple example to reproduce the issue.
Indeed I am using different data. At least there is no guarantee that 0 is
never a valid dataset while having 8 bit to be exported.
If there are NULL cells in the bands to be exported, a valid value
according to the selected output data type needs to be selected to
represent nodata, otherwise NULL cells can not be encoded, e.g. for Byte,
the value representing nodata must be in the range 0-255. This is why you
see "Checking GDAL data type and nodata value..." in the output of
r.out.gdal. The module does not always choose 0 as nodata value, this
depends on the input bands and the selected output data type.
> > > The only solution seems to be an extra alpha channel to be stored in
the resulting GDAL file (here: GeoTIFF).
> > You mean r.out.gdal should create this extra alpha channel internally?
> Yes, I thought so.
> > You could also try the PHOTOMETRIC and ALPHA creation options for
GeoTIFF with a corresponding alpha channel created manually.
> Interesting - do you have an example? Would be happy to close this
ticket as "worksforme" :)
You would need to create an alpha channel that encodes NULL cells and in
the bands to be exported replace NULL cells with some value in the range
0-255. For example
RMAP="lsat7_2000_30"
GMAP="lsat7_2000_20"
BMAP="lsat7_2000_10"
OUTNAME="lsat7_2000.tif"
# extract alpha
r.mapcalc "out_a = if(isnull($RMAP) || isnull($GMAP) || isnull($BMAP), 0,
255)"
# replace NULL cells with a valid value, extract colors
# extract red
r.mapcalc "out_r = if(isnull($RMAP), 0, #$RMAP)"
# extract green
r.mapcalc "out_g = if(isnull($GMAP), 0, #$GMAP)"
# extract blue
r.mapcalc "out_b = if(isnull($BMAP), 0, #$BMAP)"
# create group
i.group group=out_rgba input=out_r,out_g,out_b,out_a
# remove any MASK because this works only if there are
# no NULL cells in the bands to be exported
r.mask -r
# export the group
# add PROFILE=BASELINE to createopt to produce a standard TIFF file
without out GTiff extensions
r.out.gdal in=out_rgba out=$OUTNAME -cm
createopt="PHOTOMETRIC=RGB,ALPHA=YES"
A nice enhancement to r.out.gdal would be to accept multiple input raster
maps, this would avoid the need to create a group just for exporting
multiple raster maps into a single GDAL raster dataset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3130#comment:3>
