[GRASS-dev] [GRASS GIS] #3125: d.legend.vect: take into account size_column/width_column in legend
GRASS GIS trac at osgeo.org
Tue Aug 16 09:53:03 PDT 2016
  Reporter:  mlennert    |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  normal      |  Milestone:  7.0.5
 Component:  Default     |    Version:  unspecified
Resolution:              |   Keywords:  d.legend.vect, gsoc2016, symbol
       CPU:              |  size
  Unspecified            |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:5 annakrat]:
 > In [changeset:"69133" 69133]:
 > #!CommitTicketReference repository="" revision="69133"
 > d.vect: if size_column is used, write -1 to legend; symbol_size will be
 then used for point legend, see #3125
 Thanks, Anna. This solves the "side issue" of this bug. The enhancement
 wish is still valid, obviously.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3125#comment:6>
