[GRASS-dev] [GRASS GIS] #2252: wxGUI vector digitizer passing unescaped text to database
GRASS GIS trac at osgeo.org
Thu Aug 18 07:41:05 PDT 2016
  Reporter:  marisn      |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  critical    |  Milestone:  7.0.5
 Component:  wxGUI       |    Version:  svn-trunk
Resolution:              |   Keywords:  security, code injection, SQL
       CPU:              |  injection, data loss, v.db.update
  Unspecified            |   Platform:  Unspecified
Comment (by annakrat):
 Replying to [comment:14 annakrat]:
 > In [changeset:"69153" 69153]:
 > #!CommitTicketReference repository="" revision="69153"
 > wxGUI: escape single quotes when editing attributes from GUI, see #2252
 This deals with single quotes only, no security issue is solved by this.
 So please test, I can backport it and decide what else to do with this
 ticket. We should at least downgrade the priority if not close it at all.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2252#comment:15>
