[GRASS-dev] [GRASS GIS] #3134: d.legend.vect and v.colors
GRASS GIS trac at osgeo.org
Mon Aug 22 06:24:08 PDT 2016
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.3.0
 Component:  Display      |    Version:  unspecified
Resolution:               |   Keywords:  d.legend.vect, v.colors
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by annakrat):
 * type:  defect => enhancement
 * milestone:  7.2.0 => 7.3.0
Comment:
 It could work in the way that v.colors writes a legend information as a
 comment into the color file stored for that vector map. Then d.vect takes
 it and outputs it into the legend file. The problem is also that we need
 to draw a gradient in some cases depending on how many color rules are in
 there or if the attribute column (which the color table is based on) is of
 type integer or float.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3134#comment:1>
