[GRASS-dev] [GRASS GIS] #3042: Patches to make the build reproducible (fileordering, randomness)
trac at osgeo.org
Tue Aug 23 08:07:02 PDT 2016
Reporter: sebastic | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 7.0.5
Component: Compiling | Version: 7.0.4
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: Linux
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"69244" 69244]:
#!CommitTicketReference repository="" revision="69244"
If GRASS_RANDOM_SEED is set, use it to seed the random generator when
G_srand48_auto is called. This helps makeing the build reproducible
(html/random.png)
Based on 04-srand48_auto-from-SOURCE_DATE_EPOCH.patch, fix #3042
(merge r69217 from trunk)
Ticket URL: </ticket/3042#comment:14>
