[GRASS-dev] [GRASS GIS] #2799: wxGUI: display toolbar size too large
trac at osgeo.org
Tue Aug 23 14:06:59 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: wxGUI | Version: svn-releasebranch70
Resolution: | Keywords: wxGUI, size, toolbar, mapdisp
CPU: Unspecified | Platform: Unspecified
Comment (by veroandreo):
Replying to [comment:13 wenzeslaus]:
> Replying to [comment:12 veroandreo]:
> > Under Fedora 23 (wxPython 3.0.2.0)...I can no longer shrink the Map
display window and therefore, it still overlaps with layer manager even if
it is also shrunk until limit size allowed.
> Since when you can't do it? I don't know about any changes in release
branch in relation to that, so it would seem that it might be related to
some wxPython changes. Also many of these problems are coming from
wxPython itself or its interaction with underlying library, so what you
can try is to download the [http://www.wxpython.org/download.php wxPython
demo], find same widget there and if it has the bad behavior, report the
issue on the [http://trac.wxwidgets.org wxWidgets Trac] (component
wxPython).
> It doesn't seem that Map Display is setting minimal size (`SetMinSize`)
unlike for example Layer Manager window. I actually can make the window
"one pixel" big with the same wxPython (wxPython: 3.0.2.0). I guess the
question also is if you can shrink the other windows in that particular
direction.
The issue prevails here in 72 (r69220) and trunk (r69219) under fedora24.
I cannot shrink map display window, nor the window for d.vect, for
example. I am able to shrink in any direction the window of g.gui.tplot,
though. No idea :P
Ticket URL: <http://trac.osgeo.org/grass/ticket/2799#comment:18>
