[GRASS-dev] v.net.path and v.net.steiner broken
Thomas poetschie26 at gmail.com
Wed Aug 24 06:29:11 PDT 2016
Hi Martin,
thanks for your reply.
Using the NC dataset, I tried the following:
Connecting some nodes:
v.net input=points_of_interest at PERMANENT output=connected operation=arcs
file=/home/thomas/Downloads//nc_basic_spm_grass7/user1/.tmp/abbsa/6752.0
with input file:
1 200 197
2 197 202
3 202 203
4 200 203
5 203 204
6 542 197
Output:
Building topology for vector map <connected at user1>...
Registering primitives...
18 primitives registered
24 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 6
Number of primitives: 18
Number of points: 12
Number of lines: 6
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.net complete. 6 lines (network arcs) written to output.
(Wed Aug 24 17:24:50 2016) Command finished (0
sec)
Calculating the Steiner tree:
v.net.steiner input=connected at user1 output=out terminal_cats=204,542
Output:
(Wed Aug 24 17:22:56
2016)
Building graph...
Registering arcs...
(Wed Aug 24 17:22:56 2016) Command finished (0
sec)
The output file is not created. I am pretty sure this worked before.
Regards
Thomas
On 08/24/2016 04:58 PM, Martin Landa wrote:
> Hi,
> 2016-08-24 14:39 GMT+02:00 Thomas <poetschie26 at gmail.com>:
>> v.net.steiner input=in output=out terminal_cats=1,2,3
>> Building graph...
>> Registering arcs...
> please could you send us reproducable example based on North Carolina
> dataset? Martin
>> korganizer (4:4.14.10-2) to 4:16.04.3-1
>> krb5-locales (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> krb5-multidev (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> ktnef (4:4.14.10-2) to 4:16.04.3-1
>> libakonadi-calendar4 (4:4.14.10-4) to 4:4.14.10-5
>> libakonadi-contact4 (4:4.14.10-4) to 4:4.14.10-5
>> libakonadi-kabc4 (4:4.14.10-4) to 4:4.14.10-5
>> libakonadi-kcal4 (4:4.14.10-4) to 4:4.14.10-5
>> libakonadi-kde4 (4:4.14.10-4) to 4:4.14.10-5
>> libakonadi-kmime4 (4:4.14.10-4) to 4:4.14.10-5
>> libakonadi-notes4 (4:4.14.10-4) to 4:4.14.10-5
>> libakonadiprotocolinternals1 (1.13.0-8) to 1.13.0-10
>> libapt-inst2.0 (1.3~pre2) to 1.3~rc2
>> libapt-pkg5.0 (1.3~pre2) to 1.3~rc2
>> libarchive-zip-perl (1.57-1) to 1.59-1
>> libasan2 (5.4.0-6) to 5.4.1-1
>> libasound2 (1.1.1-2) to 1.1.2-1
>> libasound2-data (1.1.1-2) to 1.1.2-1
>> libasound2:i386 (1.1.1-2) to 1.1.2-1
>> libatk-adaptor (2.20.1-2) to 2.20.1-3
>> libatk-bridge2.0-0 (2.20.1-2) to 2.20.1-3
>> libatomic1 (6.1.1-10) to 6.1.1-11
>> libaudit-common (1:2.6.5-1) to 1:2.6.6-1
>> libaudit1 (1:2.6.5-1) to 1:2.6.6-1
>> libavcodec57 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libavcodec57:i386 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libavformat57 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libavresample3 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libavresample3:i386 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libavutil55 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libavutil55:i386 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libblkid1 (2.28-6) to 2.28.1-1
>> libbluetooth3 (5.36-1+b1) to 5.36-1+b2
>> libboost-dev (1.58.0.2) to 1.61.0.2
>> libbrlapi0.6 (5.3.1-3) to 5.3.1-3+b1
>> libcalendarsupport4 (4:4.14.10-2) to 4:4.14.10-7
>> libcc1-0 (6.1.1-10) to 6.1.1-11
>> libcdr-0.1-1 (0.1.3-1) to 0.1.3-1+b1
>> libcilkrts5 (6.1.1-10) to 6.1.1-11
>> libclucene-contribs1v5 (2.3.3.4-4.1) to 2.3.3.4-4.2
>> libclucene-core1v5 (2.3.3.4-4.1) to 2.3.3.4-4.2
>> libcmis-0.5-5v5 (0.5.1-4) to 0.5.1+git20160603-1
>> libcurl3-gnutls (7.47.0-1) to 7.50.1-1
>> libcurl4-gnutls-dev (7.47.0-1) to 7.50.1-1
>> libdbus-1-3 (1.10.8-1) to 1.10.10-1
>> libdbus-1-3:i386 (1.10.8-1) to 1.10.10-1
>> libdevmapper1.02.1 (2:1.02.130-1) to 2:1.02.133-1
>> libdpkg-perl (1.18.9) to 1.18.10
>> libe-book-0.1-1 (0.1.2-2+b1) to 0.1.2-3
>> libfbclient2 (2.5.6.27020.ds4-1) to 2.5.6.27020.ds4-1+b1
>> libfbembed2.5 (2.5.6.27020.ds4-1) to 2.5.6.27020.ds4-1+b1
>> libfdisk1 (2.28-6) to 2.28.1-1
>> libfdk-aac1 (1:0.1.4-dmo1) to 1:0.1.4-dmo2
>> libfdk-aac1:i386 (1:0.1.4-dmo1) to 1:0.1.4-dmo2
>> libfontconfig1 (2.11.0-6.4) to 2.11.0-6.5
>> libfontconfig1-dev (2.11.0-6.4) to 2.11.0-6.5
>> libfontconfig1:i386 (2.11.0-6.4) to 2.11.0-6.5
>> libgcc-5-dev (5.4.0-6) to 5.4.1-1
>> libgcc1 (1:6.1.1-10) to 1:6.1.1-11
>> libgcc1:i386 (1:6.1.1-10) to 1:6.1.1-11
>> libgcrypt20 (1.7.2-2) to 1.7.3-1
>> libgcrypt20:i386 (1.7.2-2) to 1.7.3-1
>> libgd3 (2.2.3-3) to 2.2.3-3+b1
>> libgdal-dev (2.1.1+dfsg-1) to 2.1.1+dfsg-1+b1
>> libgdal20 (2.1.1+dfsg-1) to 2.1.1+dfsg-1+b1
>> libgegl-0.3-0 (1:0.3.8-dmo1) to 1:0.3.8-dmo2
>> libgeotiff-dev (1.4.1-3) to 1.4.1-4
>> libgeotiff2 (1.4.1-3) to 1.4.1-4
>> libgfortran-5-dev (5.4.0-6) to 5.4.1-1
>> libgfortran3 (6.1.1-10) to 6.1.1-11
>> libgnutls30 (3.5.2-2) to 3.5.3-2
>> libgnutls30:i386 (3.5.2-2) to 3.5.3-2
>> libgomp1 (6.1.1-10) to 6.1.1-11
>> libgomp1:i386 (6.1.1-10) to 6.1.1-11
>> libgpgme++2v5 (4:4.14.10-4) to 4:4.14.10-5
>> libgs9 (9.19~dfsg-1+b1) to 9.19~dfsg-2
>> libgs9-common (9.19~dfsg-1) to 9.19~dfsg-2
>> libgssapi-krb5-2 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libgssapi-krb5-2:i386 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libgssrpc4 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libgtk-3-0 (3.20.6-2) to 3.20.7-1
>> libgtk-3-bin (3.20.6-2) to 3.20.7-1
>> libgtk-3-common (3.20.6-2) to 3.20.7-1
>> libharfbuzz-dev (1.2.7-1) to 1.2.7-1+b1
>> libharfbuzz-gobject0 (1.2.7-1) to 1.2.7-1+b1
>> libharfbuzz-icu0 (1.2.7-1) to 1.2.7-1+b1
>> libharfbuzz0b (1.2.7-1) to 1.2.7-1+b1
>> libical2 (2.0.0-0.4) to 2.0.0-0.5+b1
>> libicu-dev (55.1-7) to 57.1-2
>> libincidenceeditorsng4 (4:4.14.10-2) to 4:4.14.10-7
>> libinput-bin (1.3.3-1) to 1.4.0-1
>> libinput10 (1.3.3-1) to 1.4.0-1
>> libio-socket-ssl-perl (2.033-1) to 2.036-1
>> libitm1 (6.1.1-10) to 6.1.1-11
>> libjavascriptcoregtk-4.0-18 (2.12.3-1) to 2.12.3-1+b2
>> libjson-glib-1.0-0 (1.2.0-1) to 1.2.2-1
>> libjson-glib-1.0-common (1.2.0-1) to 1.2.2-1
>> libk5crypto3 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libk5crypto3:i386 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkabc4 (4:4.14.10-4) to 4:4.14.10-5
>> libkadm5clnt-mit10 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkadm5srv-mit10 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkalarmcal2 (4:4.14.10-4) to 4:4.14.10-5
>> libkblog4 (4:4.14.10-4) to 4:4.14.10-5
>> libkcal4 (4:4.14.10-4) to 4:4.14.10-5
>> libkcalcore4 (4:4.14.10-4) to 4:4.14.10-5
>> libkcalutils4 (4:4.14.10-4) to 4:4.14.10-5
>> libkcmutils4 (4:4.14.22-1) to 4:4.14.22-2
>> libkdb5-8 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkde3support4 (4:4.14.22-1) to 4:4.14.22-2
>> libkdeclarative5 (4:4.14.22-1) to 4:4.14.22-2
>> libkdecore5 (4:4.14.22-1) to 4:4.14.22-2
>> libkdepim4 (4:4.14.10-2) to 4:4.14.10-7
>> libkdepimdbusinterfaces4 (4:4.14.10-2) to 4:4.14.10-7
>> libkdesu5 (4:4.14.22-1) to 4:4.14.22-2
>> libkdeui5 (4:4.14.22-1) to 4:4.14.22-2
>> libkdewebkit5 (4:4.14.22-1) to 4:4.14.22-2
>> libkdgantt2-0 (4:4.14.10-2) to 4:4.14.10-7
>> libkdnssd4 (4:4.14.22-1) to 4:4.14.22-2
>> libkemoticons4 (4:4.14.22-1) to 4:4.14.22-2
>> libkfile4 (4:4.14.22-1) to 4:4.14.22-2
>> libkholidays4 (4:4.14.10-4) to 4:4.14.10-5
>> libkhtml5 (4:4.14.22-1) to 4:4.14.22-2
>> libkimap4 (4:4.14.10-4) to 4:4.14.10-5
>> libkio5 (4:4.14.22-1) to 4:4.14.22-2
>> libkjsapi4 (4:4.14.22-1) to 4:4.14.22-2
>> libkjsembed4 (4:4.14.22-1) to 4:4.14.22-2
>> libkldap4 (4:4.14.10-4) to 4:4.14.10-5
>> libkleo4 (4:4.14.10-2) to 4:4.14.10-7
>> libkmbox4 (4:4.14.10-4) to 4:4.14.10-5
>> libkmediaplayer4 (4:4.14.22-1) to 4:4.14.22-2
>> libkmime4 (4:4.14.10-4) to 4:4.14.10-5
>> libknewstuff2-4 (4:4.14.22-1) to 4:4.14.22-2
>> libknewstuff3-4 (4:4.14.22-1) to 4:4.14.22-2
>> libknotifyconfig4 (4:4.14.22-1) to 4:4.14.22-2
>> libkntlm4 (4:4.14.22-1) to 4:4.14.22-2
>> libkolabxml1v5 (1.1.4-1) to 1.1.4-1+b1
>> libkonq-common (4:16.04.2-1+b1) to 4:16.04.3-1
>> libkonq5-templates (4:16.04.2-1) to 4:16.04.3-1
>> libkonq5abi1 (4:16.04.2-1+b1) to 4:16.04.3-1
>> libkonqsidebarplugin4a (4:16.04.2-1+b1) to 4:16.04.3-1
>> libkontactinterface4a (4:4.14.10-4) to 4:4.14.10-5
>> libkparts4 (4:4.14.22-1) to 4:4.14.22-2
>> libkpathsea6 (2016.20160513.41080-4) to 2016.20160513.41080-4+b1
>> libkpgp4 (4:4.14.10-2) to 4:4.14.10-7
>> libkpimidentities4 (4:4.14.10-4) to 4:4.14.10-5
>> libkpimtextedit4 (4:4.14.10-4) to 4:4.14.10-5
>> libkpimutils4 (4:4.14.10-4) to 4:4.14.10-5
>> libkprintutils4 (4:4.14.22-1) to 4:4.14.22-2
>> libkpty4 (4:4.14.22-1) to 4:4.14.22-2
>> libkrb5-3 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkrb5-3:i386 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkrb5support0 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkrb5support0:i386 (1.14.2+dfsg-1) to 1.14.3+dfsg-1
>> libkresources4 (4:4.14.10-4) to 4:4.14.10-5
>> libkrosscore4 (4:4.14.22-1) to 4:4.14.22-2
>> libksba8 (1.3.4-3) to 1.3.4-4
>> libktexteditor4 (4:4.14.22-1) to 4:4.14.22-2
>> libktnef4 (4:4.14.10-4) to 4:4.14.10-5
>> libkxmlrpcclient4 (4:4.14.10-4) to 4:4.14.10-5
>> liblas-c3 (1.8.0-11) to 1.8.0-12
>> liblas3 (1.8.0-11) to 1.8.0-12
>> liblsan0 (6.1.1-10) to 6.1.1-11
>> liblua5.1-0 (5.1.5-8) to 5.1.5-8.1
>> liblua5.2-0 (5.2.4-1) to 5.2.4-1.1
>> libmailtransport4 (4:4.14.10-4) to 4:4.14.10-5
>> libmessagecomposer4 (4:4.14.10-2) to 4:4.14.10-7
>> libmessagecore4 (4:4.14.10-2) to 4:4.14.10-7
>> libmessageviewer4 (4:4.14.10-2) to 4:4.14.10-7
>> libmicroblog4 (4:4.14.10-4) to 4:4.14.10-5
>> libmnl0 (1.0.3-5) to 1.0.4-1
>> libmount1 (2.28-6) to 2.28.1-1
>> libmpx0 (5.4.0-6) to 5.4.1-1
>> libmspub-0.1-1 (0.1.2-2+b1) to 0.1.2-2+b2
>> libneon27-gnutls (0.30.1-3) to 0.30.1-5
>> libnepomuk4 (4:4.14.22-1) to 4:4.14.22-2
>> libnepomukquery4a (4:4.14.22-1) to 4:4.14.22-2
>> libnepomukutils4 (4:4.14.22-1) to 4:4.14.22-2
>> libnet-ssleay-perl (1.74-1) to 1.77-1
>> libnm-glib-vpn1 (1.2.2-2) to 1.2.4-2
>> libnm-glib4 (1.2.2-2) to 1.2.4-2
>> libnm-util2 (1.2.2-2) to 1.2.4-2
>> libnm0 (1.2.2-2) to 1.2.4-2
>> libnma-common (1.2.2-2) to 1.2.4-1
>> libnma0 (1.2.2-2) to 1.2.4-1
>> libnss3 (2:3.23-2) to 2:3.25-1
>> libobjc4 (6.1.1-10) to 6.1.1-11
>> libopenh264-2 (1.6.0-dmo2) to 1.6.0-dmo3
>> libopenh264-2:i386 (1.6.0-dmo2) to 1.6.0-dmo3
>> liborcus-0.11-0 (0.11.2-2) to 0.11.2-2+b1
>> libotr5 (4.1.1-1) to 4.1.1-2
>> libp11-kit0 (0.23.2-3) to 0.23.2-4
>> libp11-kit0:i386 (0.23.2-3) to 0.23.2-4
>> libpam-systemd (230-7) to 231-4
>> libpcsclite1 (1.8.17-1) to 1.8.18-1
>> libphonon4 (4:4.9.0-3) to 4:4.9.0-4
>> libphonon4qt5-4 (4:4.9.0-3) to 4:4.9.0-4
>> libpimcommon4 (4:4.14.10-2) to 4:4.14.10-7
>> libplasma3 (4:4.14.22-1) to 4:4.14.22-2
>> libpng-dev (1.6.23-1) to 1.6.24-2
>> libpng-tools (1.6.23-1) to 1.6.24-2
>> libpng16-16 (1.6.23-1) to 1.6.24-2
>> libpng16-16:i386 (1.6.23-1) to 1.6.24-2
>> libpostproc54 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libpq-dev (9.5.3-1) to 9.5.4-1
>> libpq5 (9.5.3-1) to 9.5.4-1
>> libptexenc1 (2016.20160513.41080-4) to 2016.20160513.41080-4+b1
>> libpulse-mainloop-glib0 (9.0-1.1) to 9.0-2
>> libpulse0 (9.0-1.1) to 9.0-2
>> libpulse0:i386 (9.0-1.1) to 9.0-2
>> libpulsedsp (9.0-1.1) to 9.0-2
>> libpython3.5 (3.5.2-2) to 3.5.2-3
>> libpython3.5-minimal (3.5.2-2) to 3.5.2-3
>> libpython3.5-stdlib (3.5.2-2) to 3.5.2-3
>> libqgpgme1 (4:4.14.10-4) to 4:4.14.10-5
>> libqt5concurrent5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5core5a (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5dbus5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5gui5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5network5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5opengl5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5printsupport5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5sql5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5sql5-sqlite (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5test5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5webkit5 (5.6.1+dfsg-4) to 5.6.1+dfsg-5
>> libqt5widgets5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqt5xml5 (5.6.1+dfsg-3) to 5.6.1+dfsg-3+b1
>> libqtwebkit4 (2.3.4.dfsg-8) to 2.3.4.dfsg-8.1
>> libqtwebkit4:i386 (2.3.4.dfsg-8) to 2.3.4.dfsg-8.1
>> libquadmath0 (6.1.1-10) to 6.1.1-11
>> libreoffice (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-avmedia-backend-gstreamer (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-base (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-base-core (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-base-drivers (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-calc (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-common (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-core (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-draw (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-help-en-us (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-impress (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-java-common (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-kde (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-math (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-report-builder-bin (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-sdbc-firebird (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-sdbc-hsqldb (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-style-galaxy (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-style-tango (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libreoffice-writer (1:5.1.5~rc2-1) to 1:5.2.0-2
>> libsdl-image1.2 (1.2.12-5+b6) to 1.2.12-5+b7
>> libsendlater4 (4:4.14.10-2) to 4:4.14.10-7
>> libservlet3.1-java (8.0.32-1) to 8.0.36-2
>> libsigc++-2.0-0v5 (2.8.0-1) to 2.8.0-2
>> libsmartcols1 (2.28-6) to 2.28.1-1
>> libsmi2ldbl (0.4.8+dfsg2-11) to 0.4.8+dfsg2-12
>> libsolid4 (4:4.14.22-1) to 4:4.14.22-2
>> libstdc++-5-dev (5.4.0-6) to 5.4.1-1
>> libstdc++6 (6.1.1-10) to 6.1.1-11
>> libstdc++6:i386 (6.1.1-10) to 6.1.1-11
>> libstreamanalyzer0v5 (0.7.8-2.1+b1) to 0.7.8-2.2
>> libstreams0v5 (0.7.8-2.1+b1) to 0.7.8-2.2
>> libswresample2 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libswresample2:i386 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libswscale4 (10:3.1.1-dmo3) to 10:3.1.2-dmo2
>> libsynctex1 (2016.20160513.41080-4) to 2016.20160513.41080-4+b1
>> libsyndication4 (4:4.14.10-4) to 4:4.14.10-5
>> libsystemd0 (230-7) to 231-4
>> libsystemd0:i386 (230-7) to 231-4
>> libtasn1-6 (4.8-1) to 4.9-4
>> libtasn1-6:i386 (4.8-1) to 4.9-4
>> libtemplateparser4 (4:4.14.10-2) to 4:4.14.10-7
>> libtexlua52 (2016.20160513.41080-4) to 2016.20160513.41080-4+b1
>> libtexluajit2 (2016.20160513.41080-4) to 2016.20160513.41080-4+b1
>> libthreadweaver4 (4:4.14.22-1) to 4:4.14.22-2
>> libtidy5 (1:5.2.0-1.1) to 1:5.2.0-2
>> libtsan0 (6.1.1-10) to 6.1.1-11
>> libubsan0 (6.1.1-10) to 6.1.1-11
>> libudev1 (230-7) to 231-4
>> libudev1:i386 (230-7) to 231-4
>> libuuid1 (2.28-6) to 2.28.1-1
>> libuuid1:i386 (2.28-6) to 2.28.1-1
>> libvisio-0.1-1 (0.1.5-1) to 0.1.5-1+b1
>> libvlc5 (1:2.2.4-dmo2) to 1:2.2.4-dmo3
>> libvlccore8 (1:2.2.4-dmo2) to 1:2.2.4-dmo3
>> libvpx3 (1.5.0-3) to 1.5.0-4
>> libvpx3:i386 (1.5.0-3) to 1.5.0-4
>> libwebkit2gtk-4.0-37 (2.12.3-1) to 2.12.3-1+b2
>> libwebkit2gtk-4.0-37-gtk2 (2.12.3-1) to 2.12.3-1+b2
>> libwebp-dev (0.4.4-1.1) to 0.5.1-2
>> libwireshark-data (2.0.4+gdd7746e-1) to 2.0.5+ga3be9c6-1
>> libwireshark6 (2.0.4+gdd7746e-1) to 2.0.5+ga3be9c6-1
>> libwiretap5 (2.0.4+gdd7746e-1) to 2.0.5+ga3be9c6-1
>> libwsutil6 (2.0.4+gdd7746e-1) to 2.0.5+ga3be9c6-1
>> libxcb-composite0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-damage0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-dpms0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-dri2-0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-dri2-0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-dri3-0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-dri3-0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-glx0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-glx0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-present-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb-present0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-present0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-randr0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-randr0-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb-randr0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-record0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-render0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-render0-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb-render0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-shape0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-shape0-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb-shape0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-shm0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-shm0-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb-shm0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-sync-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb-sync1 (1.11.1-1) to 1.11.1-1.1
>> libxcb-sync1:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-xfixes0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-xfixes0-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb-xfixes0:i386 (1.11.1-1) to 1.11.1-1.1
>> libxcb-xinerama0 (1.11.1-1) to 1.11.1-1.1
>> libxcb-xkb1 (1.11.1-1) to 1.11.1-1.1
>> libxcb-xv0 (1.11.1-1) to 1.11.1-1.1
>> libxcb1 (1.11.1-1) to 1.11.1-1.1
>> libxcb1-dev (1.11.1-1) to 1.11.1-1.1
>> libxcb1:i386 (1.11.1-1) to 1.11.1-1.1
>> libxerces-c-dev (3.1.3+debian-2.1) to 3.1.3+debian-2.1+b1
>> libxerces-c3.1 (3.1.3+debian-2.1) to 3.1.3+debian-2.1+b1
>> libxml-libxml-perl (2.0126+dfsg-1) to 2.0128+dfsg-1
>> libxml-twig-perl (1:3.48-1) to 1:3.50-1
>> libxml2 (2.9.4+dfsg1-1) to 2.9.4+dfsg1-1+b1
>> libxml2-dev (2.9.4+dfsg1-1) to 2.9.4+dfsg1-1+b1
>> libxml2-utils (2.9.4+dfsg1-1) to 2.9.4+dfsg1-1+b1
>> libxslt1.1 (1.1.28-4) to 1.1.29-1
>> libxtables11 (1.6.0-2) to 1.6.0-3
>> libzvbi-common (0.2.35-10) to 0.2.35-11
>> libzvbi0 (0.2.35-10+b1) to 0.2.35-11
>> libzvbi0:i386 (0.2.35-10+b1) to 0.2.35-11
>> lintian (2.5.45) to 2.5.46
>> meld (3.16.1-2) to 3.16.2-1
>> mobile-broadband-provider-info (20140317-1) to 20151214-0.1
>> mount (2.28-6) to 2.28.1-1
>> nano (2.6.1-1) to 2.6.3-1
>> network-manager (1.2.2-2) to 1.2.4-2
>> network-manager-gnome (1.2.2-2) to 1.2.4-1
>> openjdk-8-jdk (8u91-b14-3) to 8u102-b14.1-2
>> openjdk-8-jdk-headless (8u91-b14-3) to 8u102-b14.1-2
>> openjdk-8-jre (8u91-b14-3) to 8u102-b14.1-2
>> openjdk-8-jre-headless (8u91-b14-3) to 8u102-b14.1-2
>> openssh-client (1:7.2p2-8) to 1:7.3p1-1
>> openssh-server (1:7.2p2-8) to 1:7.3p1-1
>> openssh-sftp-server (1:7.2p2-8) to 1:7.3p1-1
>> oxygen-icon-theme (4:4.14.0-1) to 5:5.24.0-1
>> p11-kit (0.23.2-3) to 0.23.2-4
>> p11-kit-modules (0.23.2-3) to 0.23.2-4
>> phonon (4:4.9.0-3) to 4:4.9.0-4
>> phonon4qt5 (4:4.9.0-3) to 4:4.9.0-4
>> plasma-scriptengine-javascript (4:16.04.2-2) to 4:16.04.3-1+b1
>> printer-driver-ptouch (1.4.1-1) to 1.4.2-1
>> pulseaudio (9.0-1.1) to 9.0-2
>> pulseaudio-utils (9.0-1.1) to 9.0-2
>> python-imaging (3.2.0-2) to 3.3.0-1
>> python-libxml2 (2.9.4+dfsg1-1) to 2.9.4+dfsg1-1+b1
>> python-mutagen (1.33.2-1) to 1.34-1
>> python-pil (3.2.0-2) to 3.3.0-1
>> python-pkg-resources (20.10.1-1.1) to 25.2.0-1
>> python-pyparsing (2.1.5+dfsg1-1) to 2.1.7+dfsg1-1
>> python-setuptools (20.10.1-1.1) to 25.2.0-1
>> python3-brlapi (5.3.1-3) to 5.3.1-3+b1
>> python3-pexpect (4.0.1-1) to 4.2.0-1
>> python3-pil (3.2.0-2) to 3.3.0-1
>> python3-pkg-resources (20.10.1-1.1) to 25.2.0-1
>> python3-pyatspi (2.20.2+dfsg-1) to 2.20.2+dfsg-2
>> python3-uno (1:5.1.5~rc2-1) to 1:5.2.0-2
>> qml-module-qtwebkit (5.6.1+dfsg-4) to 5.6.1+dfsg-5
>> qt5-image-formats-plugins (5.6.1-2) to 5.6.1-2+b1
>> systemd-sysv (230-7) to 231-4
>> texlive-base (2016.20160623-1) to 2016.20160805-1
>> texlive-bibtex-extra (2016.20160623-1) to 2016.20160805-1
>> texlive-binaries (2016.20160513.41080-4) to 2016.20160513.41080-4+b1
>> texlive-extra-utils (2016.20160623-1) to 2016.20160805-1
>> texlive-font-utils (2016.20160623-1) to 2016.20160805-1
>> texlive-fonts-extra (2016.20160623-1) to 2016.20160805-1
>> texlive-fonts-extra-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-fonts-recommended (2016.20160623-1) to 2016.20160805-1
>> texlive-fonts-recommended-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-formats-extra (2016.20160623-1) to 2016.20160805-1
>> texlive-full (2016.20160623-1) to 2016.20160805-1
>> texlive-games (2016.20160623-1) to 2016.20160805-1
>> texlive-generic-extra (2016.20160623-1) to 2016.20160805-1
>> texlive-generic-recommended (2016.20160623-1) to 2016.20160805-1
>> texlive-htmlxml (2016.20160623-1) to 2016.20160805-1
>> texlive-humanities (2016.20160623-1) to 2016.20160805-1
>> texlive-humanities-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-african (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-arabic (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-chinese (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-cjk (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-cyrillic (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-czechslovak (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-english (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-european (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-french (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-german (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-greek (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-indic (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-italian (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-japanese (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-korean (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-other (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-polish (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-portuguese (2016.20160623-1) to 2016.20160805-1
>> texlive-lang-spanish (2016.20160623-1) to 2016.20160805-1
>> texlive-latex-base (2016.20160623-1) to 2016.20160805-1
>> texlive-latex-base-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-latex-extra (2016.20160623-1) to 2016.20160805-1
>> texlive-latex-extra-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-latex-recommended (2016.20160623-1) to 2016.20160805-1
>> texlive-latex-recommended-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-luatex (2016.20160623-1) to 2016.20160805-1
>> texlive-math-extra (2016.20160623-1) to 2016.20160805-1
>> texlive-metapost (2016.20160623-1) to 2016.20160805-1
>> texlive-metapost-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-music (2016.20160623-1) to 2016.20160805-1
>> texlive-omega (2016.20160623-1) to 2016.20160805-1
>> texlive-pictures (2016.20160623-1) to 2016.20160805-1
>> texlive-pictures-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-plain-extra (2016.20160623-1) to 2016.20160805-1
>> texlive-pstricks (2016.20160623-1) to 2016.20160805-1
>> texlive-pstricks-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-publishers (2016.20160623-1) to 2016.20160805-1
>> texlive-publishers-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-science (2016.20160623-1) to 2016.20160805-1
>> texlive-science-doc (2016.20160623-1) to 2016.20160805-1
>> texlive-xetex (2016.20160623-1) to 2016.20160805-1
>> udev (230-7) to 231-4
>> unar (1.10.1-1) to 1.10.1-1+b1
>> uno-libs3 (5.1.5~rc2-1) to 5.2.0-2
>> ure (5.1.5~rc2-1) to 5.2.0-2
>> usb-modeswitch-data (20160612-1) to 20160803-1
>> util-linux (2.28-6) to 2.28.1-1
>> util-linux-locales (2.28-6) to 2.28.1-1
>> uuid-dev (2.28-6) to 2.28.1-1
>> uuid-runtime (2.28-6) to 2.28.1-1
>> vlc (1:2.2.4-dmo2) to 1:2.2.4-dmo3
>> vlc-data (1:2.2.4-dmo2) to 1:2.2.4-dmo3
>> vlc-nox (1:2.2.4-dmo2) to 1:2.2.4-dmo3
>> vlc-plugin-notify (1:2.2.4-dmo2) to 1:2.2.4-dmo3
>> wget (1.18-2) to 1.18-2+b1
>> wireshark (2.0.4+gdd7746e-1) to 2.0.5+ga3be9c6-1
>> wireshark-common (2.0.4+gdd7746e-1) to 2.0.5+ga3be9c6-1
>> wireshark-qt (2.0.4+gdd7746e-1) to 2.0.5+ga3be9c6-1
>> wpasupplicant (2.3-2.4) to 2.5-2+v2.4-2
>> xbrlapi (5.3.1-3) to 5.3.1-3+b1
>> Installed the following packages:
>> accountwizard (4:16.04.3-1)
>> cpp-6 (6.1.1-11)
>> g++-6 (6.1.1-11)
>> gcc-6 (6.1.1-11)
>> gfortran-6 (6.1.1-11)
>> kde-config-mailtransport (16.04.2-2)
>> kde-spectacle (16.04.2-1)
>> kdepim-addons (16.04.3-1)
>> kdepim-themeeditors (4:16.04.3-1)
>> kdepimlibs-data (4:16.04.2-2)
>> kf5-kdepim-apps-libs-data (4:16.04.2-2)
>> kf5-kdepimlibs-kio-plugins (4:16.04.2-2)
>> kf5-messagelib-data (4:16.04.3-2)
>> libasan3 (6.1.1-11)
>> libboost-atomic1.61.0 (1.61.0+dfsg-2.1)
>> libboost-chrono1.61.0 (1.61.0+dfsg-2.1)
>> libboost-date-time1.61.0 (1.61.0+dfsg-2.1)
>> libboost-filesystem1.61.0 (1.61.0+dfsg-2.1)
>> libboost-iostreams1.61.0 (1.61.0+dfsg-2.1)
>> libboost-program-options1.61.0 (1.61.0+dfsg-2.1)
>> libboost-regex1.61.0 (1.61.0+dfsg-2.1)
>> libboost-serialization1.61.0 (1.61.0+dfsg-2.1)
>> libboost-system1.61.0 (1.61.0+dfsg-2.1)
>> libboost-thread1.61.0 (1.61.0+dfsg-2.1)
>> libboost1.61-dev (1.61.0+dfsg-2.1)
>> libgcc-6-dev (6.1.1-11)
>> libgfortran-6-dev (6.1.1-11)
>> libgrantlee-textdocument5 (5.1.0-1)
>> libicu57 (57.1-2)
>> libip4tc0 (1.6.0-3)
>> libip6tc0 (1.6.0-3)
>> libiptc0 (1.6.0-3)
>> libkf5akonadiagentbase5 (4:16.04.3-2)
>> libkf5akonadicalendar5 (16.04.2-2)
>> libkf5akonadicontact5 (4:16.04.2-2)
>> libkf5akonadicore-bin (4:16.04.3-2)
>> libkf5akonadicore5 (4:16.04.3-2)
>> libkf5akonadimime5 (4:16.04.2-2)
>> libkf5akonadinotes5 (4:16.04.2-2)
>> libkf5akonadiprivate5 (4:16.04.3-2)
>> libkf5akonadisearchdebug5 (16.04.2-2)
>> libkf5akonadisearchpim5 (16.04.2-2)
>> libkf5akonadiwidgets5 (4:16.04.3-2)
>> libkf5alarmcalendar5 (16.04.2-2)
>> libkf5calendarcore5 (4:16.04.2-1)
>> libkf5calendarsupport-data (4:16.04.2-2)
>> libkf5calendarsupport5 (4:16.04.2-2)
>> libkf5calendarutils5 (16.04.3-1)
>> libkf5contacts-data (16.04.2-1)
>> libkf5contacts5 (16.04.2-1)
>> libkf5eventviews-data (4:16.04.2-2)
>> libkf5eventviews5 (4:16.04.2-2)
>> libkf5followupreminder5 (4:16.04.2-2)
>> libkf5gapi-data (5.1.0-2)
>> libkf5gapicalendar5 (5.1.0-2)
>> libkf5gapicontacts5 (5.1.0-2)
>> libkf5gapicore5 (5.1.0-2)
>> libkf5gapitasks5 (5.1.0-2)
>> libkf5gpgmepp-pthread5 (16.04.3-1)
>> libkf5grantleetheme-plugins (16.04.3-1)
>> libkf5grantleetheme5 (16.04.3-1)
>> libkf5gravatar5 (4:16.04.2-2)
>> libkf5holidays-data (16.04.2-1)
>> libkf5holidays5 (16.04.2-1)
>> libkf5identitymanagement5 (16.04.2-1)
>> libkf5imap5 (16.04.2-1)
>> libkf5incidenceeditor-bin (16.04.2-2)
>> libkf5incidenceeditor5 (16.04.2-2)
>> libkf5kaddressbookgrantlee5 (4:16.04.2-2)
>> libkf5kdepimdbusinterfaces5 (4:16.04.2-2)
>> libkf5kdgantt2-5 (4:16.04.2-1)
>> libkf5kiogui5 (5.23.0-1)
>> libkf5kmanagesieve5 (4:16.04.2-2)
>> libkf5kontactinterface-data (16.04.2-1)
>> libkf5kontactinterface5 (16.04.2-1)
>> libkf5ksieve-data (4:16.04.2-2)
>> libkf5ksieve5 (4:16.04.2-2)
>> libkf5ksieveui5 (4:16.04.2-2)
>> libkf5ldap5 (16.04.2-1)
>> libkf5libkdepim-data (4:16.04.2-3)
>> libkf5libkdepim-plugins (4:16.04.2-3)
>> libkf5libkdepim5 (4:16.04.2-3)
>> libkf5libkleo5 (4:16.04.2-1)
>> libkf5mailcommon-plugins (4:16.04.2-2)
>> libkf5mailcommon5 (4:16.04.2-2)
>> libkf5mailimporter5 (4:16.04.2-2)
>> libkf5mailtransport-data (16.04.2-2)
>> libkf5mailtransport5 (16.04.2-2)
>> libkf5mbox5 (16.04.2-1)
>> libkf5messagecomposer5 (4:16.04.3-2)
>> libkf5messagecore5 (4:16.04.3-2)
>> libkf5messagelist5 (4:16.04.3-2)
>> libkf5messageviewer5 (4:16.04.3-2)
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
