[GRASS-dev] [GRASS GIS] #2494: d.vect.thematic broken
trac at osgeo.org
Wed Aug 24 09:39:24 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Display | Version: svn-releasebranch70
Resolution: | Keywords: d.vect.thematic, d.graph, gsoc2016
CPU: Unspecified | Platform: Linux
Comment (by annakrat):
Replying to [comment:9 mlennert]:
> Replying to [comment:8 annakrat]:
> > Replying to [comment:7 martinl]:
> > > Still an issue after GSOC 2016?
> > The bug is in the Python addon, Adam enhanced the C module (still
working on merging the changes). So I guess the bug for the addon is still
valid.
> After Adam's improvements, what is still missing in the C module which
exists in the python addon ? As soon as the first is feature-compatible
with the latter we should remove the addon, instead of maintaining the
two.
the C module can still only work with colors, line width and point size
are not implemented there yet.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2494#comment:10>
