[GRASS-dev] [GRASS GIS] #3033: Cairo and PS drivers display only one raster or vector for SVG and PS
trac at osgeo.org
Tue Aug 30 07:56:13 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: major | Milestone: 7.2.0
Component: Display | Version: svn-trunk
Resolution: | Keywords: d.mon, cairo, ps, SVG, vector
CPU: | graphics
Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
For people intersted in alternatives:
Replying to [comment:8 kuszinger]:
> Starting from the utf-8 ps.map problem ... scripts which runs well and
generates bitmap. I chose oversampling (600dpi) for 300 dpi target. ...
I'll also share my bitmap map generator once it is good enough. ... read
workspace files since compositions are already there, so no double effort
is necessary. Input will be: workspace file, target layout (landscape A4
for example) a saved region and a dpi value. ... BMP files at a given
resolution also applying opacity as set in the workspace file and then
merge them into one file. At this point I use ImageMagick.
This is now available as `m.printws` in GRASS Addons repository thanks to
kuszinger:
* https://grass.osgeo.org/grass70/manuals/addons/m.printws.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3033#comment:11>
