[GRASS-dev] [GRASS GIS] #2229: error in projection definition
trac at osgeo.org
Wed Aug 31 06:54:38 PDT 2016
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Projections/Datums | Version: svn-releasebranch70
Resolution: | Keywords: pseudomercator
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:22 neteler]:
> Can you please try the debugging tools described in
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/proj/README.txt
> --> Testing: comparing results with PROJ_DEBUG=ON CPL_DEBUG=ON
> v.proj location=Belgique31370 mapset=urbis input=rues
Reprojecting primitives ...
pj_open_lib(/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-
linux-gnu/etc/proj/nad/@null): call
fopen(/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/etc/proj/nad/@null) - failed
WARNING: pj_transform() failed: failed to load datum shift file
ERROR: Unable to re-project vector map <rues at urbis> from <Belgique31370>
GDAL: In GDALDestroy - unloading GDAL shared library.
The problem seems to be the +nadgrids=@null in the proj.4 string.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:23>
