[GRASS-dev] Delete r.le.* now?
Luca Delucchi lucadeluge at gmail.com
Wed Aug 31 23:03:51 PDT 2016
On 1 September 2016 at 03:34, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> in November 2014, r.le suite was moved to Addons as being functional and
> potentially still useful although there is r.li [1, 2]. There were some
> improvements in r.li around that time [3] and some small improvements in
> g.gui.rlisetup since than [4].
> However, more importantly, the r.le modules can't be currently compiled.
> r.le.setup needs vask library which was removed and the other modules have
> various compilation issues (which would be fixable).
> I suggest identifying what is missing in r.li from r.le and opening tickets
> for it. Then it seems that it is time to remove r.le.* from addons, so it is
> clear that they don't need to be maintained.
> In case somebody want to use r.le, the modules are still accessible in 6.4
> if I understand it correctly.
+1 for remove r.le modules
> Thanks for opinions,
> Vaclav
ciao
Luca
www.lucadelu.org
