[GRASS-dev] t.register ruins end timestamps
Sören Gebbert soerengebbert at googlemail.com
Thu Dec 1 00:19:27 PST 2016
Skip the interval option, it is not required if you specify a time interval
in the raster metadata or in an input file.
2016-12-01 9:17 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2016-12-01 9:10 GMT+01:00 Luca Delucchi <lucadeluge at gmail.com>:
> >> $ r.timestamp clip_LT51910262011267KIS01_B1
> >> 24 Sep 2011 09:39:44 / 24 Sep 2011 09:39:44
> >> After registration to spatial-temporal dataset:
> >> $ t.register inp=test maps=clip_LT51910262011267KIS01_B
> yes, but than t.register fails:
> t.register inp=test maps=clip_LT51910262011267KIS01_B1 --o -i
> WARNING: Temporal database connection defined as:
> /work/geodata/grassdata/zddp-landsat/PERMANENT/tgis/sqlite.db
> But database file does not exist.
> ERROR: The interval flag requires the start option
> Start option should be taken from timestamp, or? Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161201/066190f9/attachment.html>
