[GRASS-dev] how to reproject a raster map with absolute numbers without losing data
Markus Metz
markus.metz.giswork at gmail.com
Thu Dec 1 05:31:55 PST 2016
On Thu, Dec 1, 2016 at 1:16 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> On 01-12-16 12:01, Moritz Lennert wrote:
>> On 30/11/16 09:40, Paulo van Breugel wrote:
>>>> On Tue, Nov 29, 2016 at 5:44 PM, Moritz Lennert
>>>> > An area() function in r.mapcalc would be nice...
>>> Would indeed be a nice addition, but it isn't too difficult to compute,
>>> using:
>>> |g.region rast=afripop10 at PERMANENT|
>>> |PI=3.1415926536|
>>> |export `g.region -g`|
>>> |export `g.proj -j`|
>> This doesn't work for me as the output is
>> g.proj -j
>> +proj=longlat
>> +no_defs
>> +a=6378137
>> +rf=298.257223563
>> +towgs84=0.000,0.000,0.000
>> and +a is not acceptable as variable name.
> You are right, that should be g.proj -g I think
>>> |r.mapcalc "rcs = (sin(y()+$nsres/2) - sin(y()-$nsres/2)) * ($ewres *
>>> $PI/180) * float($a)^2";|
>> I tested this approach as well. I.e.
>> area = above formula
>> pop_density = pop / area
>> reproject pop_density
>> pop = pop_density * (ewres*nsres)
>> It is faster than the r.in.xyz approach. But it does not seem to be as
precise.
>> I still lost about 100.000 inhabitants, and more when I smooth more (the
"loss" increases from nearest neighbor to bilinear to bicubic).
Note that some of the loss happens when a non-zero cell is bordering a NULL
cell, unless you use one of the *_f interpolation methods.
> Just guessing, but an issue I had in the past with layers like Afripop is
that it may contain cells with extremely high values (a result of the
inter/extrapolation methods used to create those layers I guess, not sure
it is an issue for e.g., Wordpop). Depending on the resampling method, this
could also add to the differences in totals.
>> In order to avoid precision issues, I tried with both density by m2 and
density by km2, but results are similar.
Why not per hectare? The target cell size is close to one hectare, it could
be set to exactly one hectare.
> Does it make a difference if you use a much higher target resolution?
In theory, a higher target resolution should result in a higher total sum,
a lower target resolution in a lower total sum.
>> I don't know which part of the error comes from the use of spheroid
approximation and which part comes from the resampling at reprojection.
> It would be interesting to see how results are if using the same routine
as above (convert to densities, reproject, convert back to totals), but
using the more precise G_area_of_cell_at_row() function to compute the cell
areas.
Try the new area() function of r.mapcalc ;-)
in the source location
record absolute count as src_count
convert absolute count to density per hectare with
r.mapcalc "pop_dens_ha = 10000.0 * pop_count / area()"
in the target location
set the region according to r.proj -g
use reasonable grid geometry with e.g. g.region -pa res=100
reproject pop_dens_ha with r.proj method=bilinear_f
now density is equal to the absolute count because density is per hectare
and cell size is 10000 square meter
record absolute count as tgt_count
fix any deviations between src_count and tgt_count with
r.mapcalc "pop_count_calibrated = pop_dens_ha * $src_count / $tgt_count"
this calbration could also be done for administrative units separately
Markus M
>> But I do think that if it is important to maintain exact totals, then
the r.to.vect - v.proj - v.out.ascii - r.in.xyz solution seems to be more
reliable.
>> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161201/510ffa16/attachment-0001.html>
