[GRASS-dev] [GRASS GIS] #3215: The eval of g.proj -g fails due to white space in projection name string
trac at osgeo.org
Sun Dec 4 06:10:13 PST 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: LibGIS | Version: svn-releasebranch70
Keywords: g.proj | CPU: Unspecified
Platform: Unspecified |
Shell parsing of g.proj -g output fails:
# test case:
GRASS 7.2.0svn (nc_spm_08_grass7):~ > g.proj -g
name=Lambert Conformal Conic
proj=lcc
datum=nad83
a=6378137.0
es=0.006694380022900787
lat_1=36.16666666666666
lat_2=34.33333333333334
lat_0=33.75
lon_0=-79
x_0=609601.22
y_0=0
no_defs=defined
epsg=3358
unit=Meter
units=Meters
meters=1
eval `g.proj -g`
bash: Conformal: command not found
Quoting of the "name" key of the proj4 struct is needed in
general/g.proj/output.c but I don't know how to implement that properly.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3215>
