[GRASS-dev] python port of r.denoise (testing required)
Anna Petrášová
kratochanna at gmail.com
Mon Dec 5 20:15:45 PST 2016
Thank you for rewriting this, here is couple of brief observations.
The epsg option is currently required in the code, although it
shouldn't be necessary if you are in projected system. So it fails if
you don't specify it. Also it should probably respect nulls in the
input, now it results in -4e-06 instead of nulls.
Best,
Anna
On Mon, Dec 5, 2016 at 5:16 PM, Carlos Grohmann
<carlos.grohmann at gmail.com> wrote:
> Ok,
> I used the html from the old module. Hadn’t realized that there was a
> specific order for things in the html. Sorry.
> Thanks for the fix, Martin.
> Carlos
> On 5 Dec 2016 20:13 -0200, Markus Neteler <neteler at osgeo.org>, wrote:
> On Mon, Dec 5, 2016 at 9:23 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2016-12-05 21:14 GMT+01:00 Carlos Grohmann <carlos.grohmann at gmail.com>:
> The module itself was installed (and runs fine), but not the html help
> page. What did I miss?
> Also for addons, please follow the documentation guidelines:
> https://trac.osgeo.org/grass/wiki/Submitting/Docs
> (I think that Martin already fixed most of it)
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
