[GRASS-dev] [GRASS GIS] #3216: Dropdown menu query_column in v.to.db shows columns of wrong table
trac at osgeo.org
Tue Dec 6 04:31:57 PST 2016
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
Concerns: The query_column option in the Query tab of the v.to.db function
Issue: when selecting layer 2 in the query_layer option, the dropdown menu
of the query_column still shows the column name of the attribute table
linked to layer 1 instead of the table linked to layer 2.
Warning: if one selects a column (e.g., VAR1) from the drop-down menu and
runs v.to.db, a error is raised that "ERROR: Cannot open cursor: 'SELECT
VAR1 FROM MYTAB WHERE cat = 15'"
Note: One can still type in the name of the required column, and the
function will run without problem.
I am running GRASS 7.3 on Ubuntu 16.04
Ticket URL: <https://trac.osgeo.org/grass/ticket/3216>
