[GRASS-dev] [GRASS GIS] #3216: Dropdown menu query_column in v.to.db shows columns of wrong table
trac at osgeo.org
Tue Dec 6 05:03:58 PST 2016
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [ticket:3216 pvanbosgeo]:
> Concerns: The query_column option in the Query tab of the v.to.db
function
> Issue: when selecting layer 2 in the query_layer option, the dropdown
menu of the query_column still shows the column name of the attribute
table linked to layer 1 instead of the table linked to layer 2.
AFAIK, this is an issue in every single module where a list of columns
comes from another source than the main 'map'. AFAIU, this is inherent to
the way this widget is programmed in the GUI. ISTR that there have been
discussions about this, but don't have the time to search for this. I
would guess that the widget would need some parameter with the name and
layer of the map from which to get the list of column...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3216#comment:1>
