[GRASS-dev] [GRASS GIS] #3142: Implementing SLIC image segmentation
trac at osgeo.org
Tue Dec 6 09:22:49 PST 2016
Reporter: SCrommelinck | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Imagery | Version: unspecified
Resolution: | Keywords: SLIC image segmentation
CPU: Unspecified | Platform: Unspecified
Comment (by rashadkm):
Replying to [comment:5 mlennert]:
> Replying to [comment:4 rashadkm]:
> > Replying to [comment:3 mlennert]:
> > > After some discussion with MarkusM, I see three options, all based
on the source code published at
[http://ivrl.epfl.ch/research/superpixels], which is GPL3:
> > > * Integrate the code as is into GRASS. Disadvantage: it's C++ and
we would have to maintain it. Advantage: code exists, so less work, we
would "only" have to write the GRASS io wrapper
> > > * Translate the original code to C and integrate into GRASS.
Disadvantage: more work, we have to maintain; Advantage: no C++, no
installation by user, native implementation in GRASS
> > > * Write a GRASS module that calls the compiled command line tool.
Disadvantage: the user would have to install and compile the code.
Advantage: less work for us, others maintain
> > mortiz,
> > the second option seems better than others. right?
> I personally would prefer it, yes, but it means more work and someone
has to do it. Are you volunteering ? :-)
I am interested to work.. given help from all grass devs ;).
> > why not write new grass module. we can port/copy/translate those c++
methods into using grass api wherever possible.
> +1 (with the above reservations).
> Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3142#comment:6>
