[GRASS-dev] remove layer from vector map
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Dec 6 22:29:16 PST 2016
Hi, seems like a basic question, but can't seem to find how to remove an
attribute layer. There is an option to remove a layer in the attribute
table manager if it is linked to a table (in the remove layer tab under
manage layer). But this only removes the attribute table it seems. When I
query a map afterwards, it still shows results for two layers. Also, I
can't find a command for on the command line to remove a layer.
Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161207/70ad5fb4/attachment.html>
