[GRASS-dev] [GRASS GIS] #3220: WinGRASS not recognizing accented utf-8 (nor cp1252) attribute values
trac at osgeo.org
Wed Dec 7 07:45:49 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-releasebranch72
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 8
Comment (by razz):
Replying to [comment:1 martinl]:
> Import (`v.import/v.in.ogr`) with `encoding=cp1252` will not help?
[[BR]]
encoding=cp1252 in v.in.ogr did not help. And I'm getting them messed even
with v.db.select but without any error output:
v.db.select map=test_points
cat|id|names
1|1|ÄÖÅ
2||Æ
3||Ø
4||Å,å,Æ,æ,Ø,ø
5||ø, Ø
6||Þ
7||Ð
8||Ã…
9||æ
(Wed Dec 07 15:32:51 2016) Command finished (0 sec)
I used the stand-alone installer for both GRASS 7.0.5 and GRASS 7.2.0svn,
if it matters.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3220#comment:3>
