[GRASS-dev] [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
Rainer M Krug
Rainer at krugs.de
Wed Dec 7 07:59:42 PST 2016
Adam Dershowitz <adershowitz at exponent.com> writes:
> Michael,
> Was there ever a solution found to running GRASS on the Mac (10.11 or now 10.12) without disabling SIP?
I was using the homebrew way of installing it and it worked with enabled
SIP.
No idea about the native way.
Cheers,
Rainer
> Thanks,
> -- Adam
> From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of Michael Barton <Michael.Barton at asu.edu>
> Date: Wednesday, June 1, 2016 at 7:50 PM
> To: GRASS developers list <grass-dev at lists.osgeo.org>, grass-user grass-user <grass-user at lists.osgeo.org>
> Subject: [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
> I just posted a new binary for GRASS 7.3 built fully 64 bit, with wxPython 3.0.2.0 to the GRASS for Mac site (http://grassmac.wikidot.com)
> It turns out the previous "64bit" GRASS binary still ran 32bit Python. I had to hack the python_wrapper.py file, but this one is fully 64bit AFAICT. I also tried
> some hacks that might be a way to solve the inability to run GRASS on El Capitan with SIP enabled. There are a couple of known bugs in the wxPython 3.x
> GUI
> 1. The most serious is switching to 3D mode and back to 2D mode leaves one of the map display menu buttons corrupted. It seems the only thing you can
> do is to close the map display and open a new one.
> 2. There are also some popup lists (e.g., for switching mapsets) that do not behave as they should. You cannot select an item with a mouse (but you can
> select with arrow keys and <return>) unless you hit <escape> to destroy part of the control. Then you can use the mouse to click something.
> Please let us know if you encounter any other bug or strange behavior.
> Also, and importantly if anyone is running El Capitan, it would be great if you could reenable SIP (if you've turned it off) and see if this version runs. Of
> course, maybe I've "fixed" it so that it only runs on my system and crashes on everyone else's.
> Enjoy!
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161207/658361fa/attachment.sig>
