[GRASS-dev] GRASS 7.2RC2 problem
Anna Petrášová
kratochanna at gmail.com
Wed Dec 7 11:23:36 PST 2016
Looks like this:
http://bugs.python.org/issue26083
but not sure why I don't have the problem. Which python do you use?
On Wed, Dec 7, 2016 at 12:59 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> I did make distclean and recomplied, without send the output to a log. I
> searched for menudata.xml in my terminal output and may have found the
> problem. What do you thing?
> ValueError: insecure string pickle
> make[4]: *** [xml/menudata.xml] Error 1
> make[3]: [default] Error 2 (ignored)
> Traceback (most recent call last):
> File "core/toolboxes.py", line 903, in <module>
> sys.exit(main())
> File "core/toolboxes.py", line 887, in main
> userDefined=False)
> File "core/toolboxes.py", line 297, in createTree
> moduleItems=moduleItems)
> File "core/toolboxes.py", line 334, in toolboxes2menudata
> _expandRuntimeModules(root)
> File "core/toolboxes.py", line 634, in _expandRuntimeModules
> desc, keywords = _loadMetadata(name)
> File "core/toolboxes.py", line 671, in _loadMetadata
> task = gtask.parse_interface(module)
> File
> "/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/etc/python/grass/script/task.py",
> line 528, in parse_interface
> tree = etree.fromstring(get_interface_description(name))
> File
> line 480, in get_interface_description
> stderr=PIPE)
> File
> "/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/etc/python/grass/script/core.py",
> line 74, in __init__
> subprocess.Popen.__init__(self, args, **kwargs)
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py",
> line 710, in __init__
> errread, errwrite)
> File
> line 1334, in _execute_child
> child_exception = pickle.loads(data)
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/pickle.py",
> line 1382, in loads
> return Unpickler(file).load()
> File
> line 858, in load
> dispatch[key](self)
> File
> line 966, in load_string
> raise ValueError, "insecure string pickle"
> make[4]: *** [xml/module_tree_menudata.xml] Error 1
> File "core/menutree.py", line 245, in <module>
> menudata = LayerManagerMenuData(filename)
> File
> "/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/lmgr/menudata.py",
> line 42, in __init__
> self, filename, expandAddons=expandAddons)
> File
> "/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/core/menutree.py",
> line 65, in __init__
> xmlTree = etree.parse(filename)
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
> line 1182, in parse
> tree.parse(source, parser)
> File
> line 657, in parse
> self._root = parser.close()
> File
> line 1654, in close
> self._raiseerror(v)
> File
> line 1506, in _raiseerror
> raise err
> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
> make[4]: *** [menustrings.py] Error 1
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 6, 2016, at 9:04 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> I'm at home and can't check until tomorrow. Previously, the python make
> section that generated the xml files failed. IIRC, with some other similar
> issues in the past, the error (which might be in the make.log) suggested it
> was looking for 64bit python when I'm compiling with 32bit python because we
> are still stuck with wxPython 2.8.12.
> Michael
> C. Michael Barton
> On Dec 6, 2016, at 8:57 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Dec 6, 2016 at 7:03 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>> Here is what I had to do before.
> What happens when you do it now? Or you already did that now?
>> Compile normally (my steps 1-5)
>> 5.1. Do NOT create binary distribution yet (do not run make bindist)
>> 5.2. Launch GRASS (existing binary, preferably of same version)
>> 5.3. cd to source wxpython folder. e.g.,
>> cd /Users/cmbarton/grass_source/grass_trunk/gui/wxpython
>> 5.4. recompile from within GRASS environment
>> make clean
>> make
>> 6.0 then run bindist
