[GRASS-dev] [GRASS GIS] #3220: WinGRASS not recognizing accented utf-8 (nor cp1252) attribute values
GRASS GIS trac at osgeo.org
Sun Dec 11 01:39:33 PST 2016
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Default      |    Version:  svn-releasebranch72
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MSWindows 8
Comment (by marisn):
 A comment without looking into actual code.
 It is necessary to provide clear info on reproducing the issue. Crucial
 info is:
 * Windows locale (will influence assumed encoding);
 * The mechanism of executing example command (CMD.exe will have different
 encoding than other places. Think ANSI vs OEM).
 Some related reading:
 https://trac.osgeo.org/grass/ticket/2525#comment:1
 https://trac.osgeo.org/grass/ticket/2120#comment:10
 http://stackoverflow.com/a/17177904
 https://bugs.python.org/issue6135
Ticket URL: <https://trac.osgeo.org/grass/ticket/3220#comment:7>
