[GRASS-dev] remove layer from vector map
Paulo van Breugel p.vanbreugel at gmail.com
Wed Dec 14 03:08:12 PST 2016
On 07-12-16 08:20, Moritz Lennert wrote:
> Le 7 décembre 2016 07:29:16 GMT+01:00, Paulo van Breugel <p.vanbreugel at gmail.com> a écrit :
>> Hi, seems like a basic question, but can't seem to find how to remove
>> an
>> attribute layer. There is an option to remove a layer in the attribute
>> table manager if it is linked to a table (in the remove layer tab under
>> manage layer). But this only removes the attribute table it seems. When
>> I
>> query a map afterwards, it still shows results for two layers. Also, I
>> can't find a command for on the command line to remove a layer.
>  From memory:
> v.category YourMap op=del cat=-1 layer=YourLayer
Thanks, that works.
> Moritz
