[GRASS-dev] [GRASS GIS] #3222: Add layer with table in Attribute table manager fails
GRASS GIS trac at osgeo.org
Wed Dec 14 03:35:52 PST 2016
 Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:
Component:  Default      |    Version:  svn-trunk
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 I am trying to add a layer with attribute table to a vector layer using
 the Attribute Table Manager, following the steps:
 * Go to to the tab 'Manage layers' and then the tab 'add layer'
 * Create a table using the 'create table' option.
 * add a layer with the 'insert record for each category into table' option
 toggled.
 This results in an error window "ERROR: Layer index out of range".
 Adding a layer and table with v.category and v.add.table works
Ticket URL: <https://trac.osgeo.org/grass/ticket/3222>
