[GRASS-dev] [GRASS GIS] #3222: Add layer with table in Attribute table manager fails
GRASS GIS trac at osgeo.org
Wed Dec 14 04:04:23 PST 2016
  Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.6
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  dbmgr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by hellik):
 Replying to [ticket:3222 pvanbosgeo]:
 > I am trying to add a layer with attribute table to a vector layer using
 the Attribute Table Manager, following the steps:
 > * Go to to the tab 'Manage layers' and then the tab 'add layer'
 > * Create a table using the 'create table' option.
 > * add a layer with the 'insert record for each category into table'
 option toggled.
 > This results in an error window "ERROR: Layer index out of range".
 > Adding a layer and table with v.category and v.add.table works
 confirmed on testing at
 System Info
 GRASS version: 7.3.svn
 GRASS SVN revision: r70070
 Build date: 2016-12-13
 Build platform: x86_64-w64-mingw32
 GDAL: 2.1.2
 PROJ.4: 4.9.3
 GEOS: 3.5.0
 SQLite: 3.14.1
 Python: 2.7.5
 wxPython: 2.8.12.1
 Platform: Windows-8-6.2.9200 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3222#comment:2>
