[GRASS-dev] GRASS 7.2RC2 problem
Michael Barton
Michael.Barton at asu.edu
Thu Dec 15 12:37:14 PST 2016
Forgot to add the log.
The upshot is that currently, GRASS will not compile successfully on the Mac and I don't have any idea of how to fix it.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 6, 2016, at 4:48 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Tue, Dec 6, 2016 at 6:45 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> They both have 0 bytes. This is the same problem we had many months back. I had a clunky workaround but it has not been necessary for some time now.
> So what happens if you run those commands manually? Such as:
> python core/toolboxes.py > xml/menudata.xml
>> Michael
>> C. Michael Barton
>> www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=HVEqhwl3Ll85E3gVJ25-oDCdT7JU_OnVtUNoG9MOuKw&s=GXvLOrXadWKzYOPfMagBRRvfDFP_4-JVAje415O0QYM&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=HVEqhwl3Ll85E3gVJ25-oDCdT7JU_OnVtUNoG9MOuKw&s=lHTmwDZwrR0-7VdqX_upALaAib4pH4PlSL2uQLMoKM4&e=
>>> On Dec 6, 2016, at 4:36 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>> There is indeed no error in the log. I can see:
>>> /usr/bin/install -c -m 644 xml/menudata.xml
>>> /Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/menudata.xml
>>> /usr/bin/install -c -m 644 xml/module_tree_menudata.xml
>>> /Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/module_tree_menudata.xml
>>> so the xml files are on the right places. Could you verify that? Are
>>> these files correct? Then when you make install, are these files in
>>> the grass7 app?
>>> Anna
>>> On Tue, Dec 6, 2016 at 5:49 PM, Martin Landa <landa.martin at gmail.com> wrote:
>>>> 2016-12-06 23:45 GMT+01:00 Michael Barton <Michael.Barton at asu.edu>:
>>>>> It is. We don't know what the problem is. I have a guess on this though. It
>>>>> may be a problem with generating the xml code for the addons menu. We had
>>>>> this problem awhile back.
>>>> without full log (run make distclean before configure && make) we
>>>> cannot move from this point (this issue has been reported 7 days ago).
>>>> Thanks, Ma
>>>>> On Nov 29, 2016 10:13 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>>>>>> Yesterday I compiled GRASS 7.2 RC2 with no errors. Today I tried to test
>>>>>> it before posting and got the following error:
>>>>>> GRASS 7.2.0RC2 (Global_latlon):~ > Traceback (most recent call last):
>>>>>> File "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py",
>>>>>> line 158, in <module>
>>>>>> sys.exit(main())
>>>>>> line 145, in main
>>>>>> app = GMApp(workspaceFile)
>>>>>> line 48, in __init__
>>>>>> wx.App.__init__(self, False)
>>>>>> File
>>>>>> "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
>>>>>> line 7981, in __init__
>>>>>> self._BootstrapApp()
>>>>>> File
>>>>>> line 7555, in _BootstrapApp
>>>>>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>>>>> line 92, in OnInit
>>>>>> workspace=self.workspaceFile)
>>>>>> File
>>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
>>>>>> line 129, in __init__
>>>>>> self._menuTreeBuilder = LayerManagerMenuData()
>>>>>> File
>>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
>>>>>> line 42, in __init__
>>>>>> self, filename, expandAddons=expandAddons)
>>>>>> File
>>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py",
>>>>>> line 65, in __init__
>>>>>> xmlTree = etree.parse(filename)
>>>>>> File
>>>>>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
>>>>>> line 1182, in parse
>>>>>> tree.parse(source, parser)
>>>>>> File
>>>>>> line 657, in parse
>>>>>> self._root = parser.close()
>>>>>> File
>>>>>> line 1654, in close
>>>>>> self._raiseerror(v)
>>>>>> File
>>>>>> line 1506, in _raiseerror
>>>>>> raise err
>>>>>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>>>>>> Any idea what this is?
>>>>> Is this yet a showstopper for the final release?
>>>>> Markus
>>>>> _______________________________________________
>>>>> grass-dev mailing list
>>>>> grass-dev at lists.osgeo.org
>>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mailman_listinfo_grass-2Ddev&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=wzegbuCgj3FNHt2EvfUw_NSkDRyjw3UfEGjra7XMnrg&s=A_5YGAlkyo-TX5DrYQbXazvt29qM0wVR54KhVJyCqYY&e=
>>>> Martin Landa
>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__geo.fsv.cvut.cz_gwiki_Landa&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=wzegbuCgj3FNHt2EvfUw_NSkDRyjw3UfEGjra7XMnrg&s=IW0FiwKY9TZVJMKYQEnTHnyLEgTOUToc6aMN8x1tbGA&e=
>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__gismentors.cz_mentors_landa&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=wzegbuCgj3FNHt2EvfUw_NSkDRyjw3UfEGjra7XMnrg&s=RdDtLFNgIXcXjzm3ihlgoJmzAe75YPYatIR81LIHwz0&e=
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161215/111d113f/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161215/111d113f/attachment-0001.txt>
