[GRASS-dev] i.superpixels.slic ( was: #3142 Implementing SLIC image segmentation)
Rashad Kanavath
mohammedrashadkm at gmail.com
Mon Dec 19 09:02:41 PST 2016
Hello
On Mon, Dec 19, 2016 at 5:30 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Hi Rashad,
> Another reflection: IIUC, in the current implementation all pixel values
> from all bands are read into memory. This can quickly become a limiting
> factor when working with very large images.
> For now we can work this way until the general algorithm is clear, but in
> the long run, I imagine that the segment library should be used to only
> load parts of the data at a time.
I had asked this question myself :-).
But then I don't know how to deal with large datasets in grass. I Couldn't
find any method to allow streaming/tiled processing. That would be awesome!
I look forward reply from MarkusM for this.
Thanks again.
> Maybe MarkusM help us with that ?
> Moritz
> On 19/12/16 16:05, Moritz Lennert wrote:
>> On 19/12/16 09:38, Rashad Kanavath wrote:
>>> On Sun, Dec 18, 2016 at 2:53 PM, Moritz Lennert
>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>>> wrote:
>>> On 18/12/16 14:01, Rashad Kanavath wrote:
>>> Hello,
>>> As promised, I had pushed code to G7 addons repo
>>> https://trac.osgeo.org/grass/browser/grass-addons/grass7/ima
>>> gery/i.superpixels.slic
>>> <https://trac.osgeo.org/grass/browser/grass-addons/grass7/im
>>> agery/i.superpixels.slic>
>>> agery/i.superpixels.slic>>
>>> Great job, thanks a lot !
>>> I had tested with some small datasets and is working.
>>> More testing welcome :)
>>> I get the following warning during installation:
>>> main.c: In function ‘main’:
>>> main.c:514:13: warning: implicit declaration of function ‘min’
>>> [-Wimplicit-function-declaration]
>>> seedx = min(g_width-1,seedx);
>>> I think you have to explicitely define min() through a macro, or
>>> AFAIK you can use fmin() as elsewhere in the code.
>>> I will push a fix for that.
>> Thanks, but your fix creates another error:
>> main.c:514:18: error: expected expression before ‘double’
>> seedx = fmin(double (g_width-1), seedx);
>> main.c:514:13: error: too few arguments to function ‘fmin’
>> In file included from /usr/include/features.h:364:0,
>> from /usr/include/stdio.h:27,
>> from main.c:21:
>> /usr/include/x86_64-linux-gnu/bits/mathcalls.h:360:1: note: declared here
>> __MATHCALLX (fmin,, (_Mdouble_ __x, _Mdouble_ __y), (__const__));
>> make: *** [OBJ.x86_64-pc-linux-gnu/main.o] Erreur 1
>> as 'double' is not a function, so double(g_width-1)) doesn't make sense.
>> If you want to cast g_width-1 to double before submitting it to fmin(),
>> then AFAIK this would have to be:
>> seedx = fmin ((double) (g_width-1), seedx)
>> However, again AFAIK, this type conversion is done implicitely anyhow,
>> so you can just write:
>> seedx = fmin (g_width-1, seedx)
>>> Also:
>>> - The output as it is now is not very useful. What we would need is
>>> a map with each pixel containing the label of the superpixel it
>>> belongs to. In the original code, there are both outputs: i) an
>>> image of the superpixel limits overlayed over the original image,
>>> ii) the labeled pixels
>>> you need contour segments as seperate output and also the current one.
>>> right?
>> I don't know what you understand by 'contour segments'. What we would
>> need would be an output similar to that of i.segment, i.e. each pixel
>> having the id of the superpixel it belongs to (and there would be no
>> specific boundary pixels).
>> The current output is actually not useful at all for us, I think. It is
>> used for visualisation purposes in the original software, but in GRASS
>> we can just vectorize the superpixels if we want to display their
>> contours on top of the original image.
>> This means you can just get rid of the entire boundary detection part
>> (lines 730-817 IIUC), and just output the klabels array to a map.
>> Something like this seems to do the job (cf superpixel_id_output.png):
>> int r, z;
>> CELL *ubuff[nrows];
>> for( r = 0; r < nrows; r++ )
>> ubuff[r] = Rast_allocate_c_buf();
>> z = 0;
>> for (y = 0; y < nrows; y++)
>> for(x = 0; x < ncols; x++)
>> ubuff[y][x] = klabels[z]+1; /* +1 to avoid
>> category value 0*/
>> z++;
>> outfd = Rast_open_new(result, CELL_TYPE);
>> for (z = 0; z < nrows; z++)
>> Rast_put_row(outfd, ubuff[z], CELL_TYPE);
>> G_free(ubuff[z]);
>>> - Linked to the above: currently the superpixel boundaries are two
>>> pixels wide. A one-pixel boundary would be enough.
>>> you can adjust no of superpixels with k. default now is 200
>> Yes, but this is not what I am talking about.
>> Here's an example with the NC demo dataset:
>> g.region rast=lsat7_2002_10 -p
>> i.superpixels.slic red=lsat7_2002_30 green=lsat7_2002_20
>> blue=lsat7_2002_10 iter=500 k=500 output=superpixels
>> d.rgb red=lsat7_2002_30 green=lsat7_2002_20 blue=lsat7_2002_10
>> d.rast map=superpixels values=1
>> Then zoom in close, and look at the boundaries (see
>> superpixels_large_boudaries.png attached). You can see that the boundary
>> is at least 2 pixels wide. I would expect a one-pixel boundary to be
>> enough.
>> But this is actually not very important since, as mentioned above, the
>> output with the boundaries is not really useful IMHO.
>>> - I don't know the details of the algorithm well enough, but would
>>> it be possible to extend it beyond the use of r,g,b maps as input.
>>> Ideally, the use should be able to provide a group as input and all
>>> maps in the group are used in the definition of the superpixels.
>>> This should also include the case when you only have one band (e.g.
>>> black and white orthophoto).
>>> I need help in understanding this part. because in code, it operates on
>>> lab color space. first it takes RBG and convert to LAB. This is reason,
>>> I had to put red,green,blue parameters.
>> I think that the authors come more from pattern recognition in images,
>> and link that pattern recognition to human recognizable color space. And
>> LAB color space is considered closer to human perception.
>> After perfunctory reading of their technical paper and a glance over the
>> code, however, I don't really see any reason why going through LAB color
>> space would be necessary.
>> I think you can just skip the whole translation to LAB space part and
>> use as many bands as you wish. The only difference would be that you
>> would use kseedsl, kseedsa, kseedsb, but as many kseedsN as you have
>> bands (possibly an array of arrays with N arrays of seed arrays where N
>> is the number bands), and spectral distance would be calculated not by
>> dist = (L[i] - kseedsl[n])*(L[i] - kseedsl[n]) +
>> (A[i] - kseedsa[n])*(A[i] - kseedsa[n]) +
>> (B[i] - kseedsb[n])*(B[i] - kseedsb[n]);
>> but through the equivalent for whatever number of bands you have.
>> So, for me, the next steps would be:
>> - implementation of id output as above
>> - implementation of the algorithm using any number of bands (without
>> going through the LAB color space)
>> - implementation of user defined compactness, and, better yet, SLICO,
>> i.e. automatic detection of compactness. More info and the source code
>> of that are at the bottom of http://ivrl.epfl.ch/research/superpixels.
>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161219/55936c69/attachment.html>
