[GRASS-dev] i.superpixels.slic ( was: #3142 Implementing SLIC image segmentation)
Rashad Kanavath mohammedrashadkm at gmail.com
Tue Dec 20 01:50:45 PST 2016
On Tue, Dec 20, 2016 at 10:04 AM, Markus Metz <markus.metz.giswork at gmail.com
> wrote:
> On Mon, Dec 19, 2016 at 6:02 PM, Rashad Kanavath <
> mohammedrashadkm at gmail.com> wrote:
> > Hello
> > On Mon, Dec 19, 2016 at 5:30 PM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
> >> Hi Rashad,
> >> Another reflection: IIUC, in the current implementation all pixel
> values from all bands are read into memory. This can quickly become a
> limiting factor when working with very large images.
> >> For now we can work this way until the general algorithm is clear, but
> in the long run, I imagine that the segment library should be used to only
> load parts of the data at a time.
> > I had asked this question myself :-).
> >  But then I don't know how to deal with large datasets in grass. I
> Couldn't find any method to allow streaming/tiled processing. That would be
> awesome!
> > I look forward reply from MarkusM for this.
> We can use some methods from i.segment to handle large datasets, i.e.
> using the segment library, adding a memory option etc. Also keeping track
> of superpixel characteristics can be adopted from keeping track of region
> properties in the region growing algorithm.
> About RGB or LAB, I agree with Moritz that this does not matter, instead
> it is more important that any number of bands can be used as input, and any
> kind of data, e.g. mixing vegetation indices with spectral bands.
> Thanks a lot for the implementation! Since this is work in progress, the
> module could be moved from grass-addons to sandbox until the name and
> options are fixed?
How do I move the code to sandbox.?
> Markus M
> > Thanks again.
> >> Maybe MarkusM help us with that ?
> >> Moritz
> >> On 19/12/16 16:05, Moritz Lennert wrote:
> >>> On 19/12/16 09:38, Rashad Kanavath wrote:
> >>>> On Sun, Dec 18, 2016 at 2:53 PM, Moritz Lennert
> >>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
> wrote:
> >>>>     On 18/12/16 14:01, Rashad Kanavath wrote:
> >>>>         Hello,
> >>>>         As promised, I had pushed code to G7 addons repo
> >>>>         https://trac.osgeo.org/grass/browser/grass-addons/grass7/ima
> gery/i.superpixels.slic
> >>>>         <https://trac.osgeo.org/grass/browser/grass-addons/grass7/im
> agery/i.superpixels.slic>
> agery/i.superpixels.slic>>
> >>>>     Great job, thanks a lot !
> >>>>         I had tested with some small datasets and is working.
> >>>>         More testing welcome :)
> >>>>     I get the following warning during installation:
> >>>>     main.c: In function ‘main’:
> >>>>     main.c:514:13: warning: implicit declaration of function ‘min’
> >>>>     [-Wimplicit-function-declaration]
> >>>>          seedx = min(g_width-1,seedx);
> >>>>     I think you have to explicitely define min() through a macro, or
> >>>>     AFAIK you can use fmin() as elsewhere in the code.
> >>>> I will push a fix for that.
> >>> Thanks, but your fix creates another error:
> >>> main.c:514:18: error: expected expression before ‘double’
> >>>       seedx = fmin(double (g_width-1), seedx);
> >>> main.c:514:13: error: too few arguments to function ‘fmin’
> >>> In file included from /usr/include/features.h:364:0,
> >>>                   from /usr/include/stdio.h:27,
> >>>                   from main.c:21:
> >>> /usr/include/x86_64-linux-gnu/bits/mathcalls.h:360:1: note: declared
> here
> >>>   __MATHCALLX (fmin,, (_Mdouble_ __x, _Mdouble_ __y), (__const__));
> >>> make: *** [OBJ.x86_64-pc-linux-gnu/main.o] Erreur 1
> >>> as 'double' is not a function, so double(g_width-1)) doesn't make
> sense.
> >>> If you want to cast g_width-1 to double before submitting it to fmin(),
> >>> then AFAIK this would have to be:
> >>> seedx = fmin ((double) (g_width-1), seedx)
> >>> However, again AFAIK, this type conversion is done implicitely anyhow,
> >>> so you can just write:
> >>> seedx = fmin (g_width-1, seedx)
> >>>>     Also:
> >>>>     - The output as it is now is not very useful. What we would need
> is
> >>>>     a map with each pixel containing the label of the superpixel it
> >>>>     belongs to. In the original code, there are both outputs: i) an
> >>>>     image of the superpixel limits overlayed over the original image,
> >>>>     ii) the labeled pixels
> >>>> you need contour segments as seperate output and also the current one.
> >>>> right?
> >>> I don't know what you understand by 'contour segments'. What we would
> >>> need would be an output similar to that of i.segment, i.e. each pixel
> >>> having the id of the superpixel it belongs to (and there would be no
> >>> specific boundary pixels).
> >>> The current output is actually not useful at all for us, I think. It is
> >>> used for visualisation purposes in the original software, but in GRASS
> >>> we can just vectorize the superpixels if we want to display their
> >>> contours on top of the original image.
> >>> This means you can just get rid of the entire boundary detection part
> >>> (lines 730-817 IIUC), and just output the klabels array to a map.
> >>> Something like this seems to do the job (cf superpixel_id_output.png):
> >>>          int r, z;
> >>>          CELL *ubuff[nrows];
> >>>          for(  r = 0; r < nrows; r++ )
> >>>                  ubuff[r] = Rast_allocate_c_buf();
> >>>          z = 0;
> >>>          for (y = 0; y < nrows; y++)
> >>>                  for(x = 0; x < ncols; x++)
> >>>                          ubuff[y][x] = klabels[z]+1; /* +1 to avoid
> >>> category value 0*/
> >>>                          z++;
> >>>      outfd = Rast_open_new(result, CELL_TYPE);
> >>>          for (z = 0; z < nrows; z++)
> >>>          Rast_put_row(outfd, ubuff[z], CELL_TYPE);
> >>>                  G_free(ubuff[z]);
> >>>>     - Linked to the above: currently the superpixel boundaries are two
> >>>>     pixels wide. A one-pixel boundary would be enough.
> >>>> you can adjust no of superpixels with k. default now is 200
> >>> Yes, but this is not what I am talking about.
> >>> Here's an example with the NC demo dataset:
> >>> g.region rast=lsat7_2002_10 -p
> >>> i.superpixels.slic red=lsat7_2002_30 green=lsat7_2002_20
> >>> blue=lsat7_2002_10 iter=500 k=500 output=superpixels
> >>> d.rgb red=lsat7_2002_30 green=lsat7_2002_20 blue=lsat7_2002_10
> >>> d.rast map=superpixels values=1
> >>> Then zoom in close, and look at the boundaries (see
> >>> superpixels_large_boudaries.png attached). You can see that the
> boundary
> >>> is at least 2 pixels wide. I would expect a one-pixel boundary to be
> enough.
> >>> But this is actually not very important since, as mentioned above, the
> >>> output with the boundaries is not really useful IMHO.
> >>>>     - I don't know the details of the algorithm well enough, but would
> >>>>     it be possible to extend it beyond the use of r,g,b maps as input.
> >>>>     Ideally, the use should be able to provide a group as input and
> all
> >>>>     maps in the group are used in the definition of the superpixels.
> >>>>     This should also include the case when you only have one band
> (e.g.
> >>>>     black and white orthophoto).
> >>>> I need help in understanding this part. because in code, it operates
> on
> >>>> lab color space. first it takes RBG and convert to LAB. This is
> reason,
> >>>> I had to put red,green,blue parameters.
> >>> I think that the authors come more from pattern recognition in images,
> >>> and link that pattern recognition to human recognizable color space.
> And
> >>> LAB color space is considered closer to human perception.
> >>> After perfunctory reading of their technical paper and a glance over
> the
> >>> code, however, I don't really see any reason why going through LAB
> color
> >>> space would be necessary.
> >>> I think you can just skip the whole translation to LAB space part and
> >>> use as many bands as you wish. The only difference would be that you
> >>> would use kseedsl, kseedsa, kseedsb, but as many kseedsN as you have
> >>> bands (possibly an array of arrays with N arrays of seed arrays where N
> >>> is the number bands), and spectral distance would be calculated not by
> >>> dist =  (L[i] - kseedsl[n])*(L[i] - kseedsl[n]) +
> >>>         (A[i] - kseedsa[n])*(A[i] - kseedsa[n]) +
> >>>         (B[i] - kseedsb[n])*(B[i] - kseedsb[n]);
> >>> but through the equivalent for whatever number of bands you have.
> >>> So, for me, the next steps would be:
> >>> - implementation of id output as above
> >>> - implementation of the algorithm using any number of bands (without
> >>> going through the LAB color space)
> >>> - implementation of user defined compactness, and, better yet, SLICO,
> >>> i.e. automatic detection of compactness. More info and the source code
> >>> of that are at the bottom of http://ivrl.epfl.ch/research/superpixels.
> >>> Moritz
> >>> _______________________________________________
> >>> grass-dev mailing list
> >>> grass-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> > Regards,
> >    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161220/82d1b243/attachment-0001.html>
