[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
trac at osgeo.org
Tue Dec 20 07:53:13 PST 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 7.0.6
Component: Packaging | Version: svn-releasebranch70
Resolution: | Keywords: lasinfo, r.in.lidar, v.in.lidar,
| r3.in.lidar, libLAS
CPU: x86-64 | Platform: Unspecified
Comment (by martinl):
Replying to [comment:18 annakrat]:
> I tested on 2 machines. First one is freshly installed Windows 10 and
r.in.lidar does not even start. Here it seems some of the needed dlls are
missing. When running r.in.lidar from terminal, it says msvcp120.dll and
msvcr120.dll are missing. So I found them in some obscure system directory
and copied them to extrabin and then everything works.
standalone or osgeo4w installer. If standalone did you installed Microsoft
Runtime Libs? Ma
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996#comment:19>
