[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
trac at osgeo.org
Tue Dec 20 11:57:11 PST 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 7.0.6
Component: Packaging | Version: svn-releasebranch70
Resolution: | Keywords: lasinfo, r.in.lidar, v.in.lidar,
| r3.in.lidar, libLAS
CPU: x86-64 | Platform: Unspecified
Comment (by annakrat):
Replying to [comment:18 annakrat]:
> Then I tested an older computer. Here nothing works, but it behaves
differently. r.in.lidar starts, but then it says GRASS7 has stopped
working. Copying those dlls does not help. I tested different grass
versions, nothing works.
Regarding this second problem I described (which seems to be unrelated to
the first one), I tested a different Windows machine and it worked there.
So it's not easily reproducible, but there is still some problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996#comment:26>
