[GRASS-dev] [GRASS GIS] #3226: v.select: how to handle situation where no features are found
trac at osgeo.org
Tue Dec 20 23:38:23 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.select
CPU: Unspecified | Platform: Unspecified
Comment (by lucadelu):
Replying to [comment:1 mmetz]:
> I agree. If no features are selected, there should be no output map.
This is particularly useful for automated processing, otherwise you would
need to check if the output map contains any features at al. It is much
simpler to check if the expected output map exists, granted that v.select
finished successfully.
+1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3226#comment:2>
