[GRASS-dev] [GRASS GIS] #2846: g.gui.rlisetup: show where new config file is created
trac at osgeo.org
Wed Dec 21 01:29:27 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: reopened
Priority: normal | Milestone: 7.4.0
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by hellik):
Replying to [comment:5 mlennert]:
> Replying to [comment:4 hellik]:
> > Replying to [comment:3 lucadelu]:
> > > Replying to [comment:2 mlennert]:
> > > > Replying to [ticket:2846 hellik]:
> > > > > it would be nice if there would be an information of the whole
path to the file which could be copy/paste as input to the r.li.*-modules.
> > > > You should not use the absolute path in the r.li.* modules. Just
the file name. You can list existing files with g.gui.rlisetup. So,
normally, no need to see the absolute path.
> > > I confirm this
> > > > However, ascii output files are also stored in the same path, and
this is a bit more of a nuisance as you then have to navigate there to
find the file. I imagine (but haven't checked) that this was done to
ensure that any other r.li.* module can potentially, easily find the ascii
output of another, but are there many modules that read this kind of
output ?
> > > Maybe you can open an enhancement ticket for this?
> > > Can I suggest to close this ticket as invalid? I think it is better
to use g.gui.rlisetup to create or modify the r.li configuration files.
> > What kind of invalid is to show the path to config (and maybe the
output) files?
> I think that a message with the full path will give the illusion that
this is what users should use, while what they actually should use is just
the name. Maybe to make that even clearer, the r.li.* modules should
provide a dropdown list of available config files (such as the list of
signature files you can get in i.maxlik). Again, something for an
enhancement ticket.
a dropdown list would be indeed the best solution.
> So, maybe invalid is a bit harsh, and wontfix is better, but I agree
with Luca on the conclusion.
as long there is no dropdown list, IMHO the user is left alone to know
names if there are several config files.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2846#comment:11>
