[GRASS-dev] [GRASS GIS] #2885: wxGUI Location Creation Wizard: UnicodeEncoreError when GISDBASE has accents in path
trac at osgeo.org
Mon Feb 1 08:20:33 PST 2016
accents in path
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: location wizard encoding | CPU: Unspecified
Platform: Unspecified |
In trunk (but not int release70), testing with a grass database located in
/home/mlennert/DonnéesGRASS, I get the following error when trying to
create a new location with the location creation wizard. The error appears
when I click on the 'Finish' button, and the location is not created.
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/gis_set.py", line 510, in OnWizard
grassdatabase = self.tgisdbase.GetValue())
gnu/gui/wxpython/location_wizard/wizard.py", line 1918, in __init__
msg = self.OnWizFinished()
gnu/gui/wxpython/location_wizard/wizard.py", line 2067, in OnWizFinished
current_gdb = grass.gisenv()['GISDBASE'].decode(sys.stdin.encoding)
File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 19: ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2885>
