[GRASS-dev] [GRASS GIS] #2889: wxGUI: paste into modeller "Add GRASS coomand" dialog hangs it
GRASS GIS trac at osgeo.org
Tue Feb 2 06:29:20 PST 2016
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.1.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  modeller
       CPU:  Unspecified  |   Platform:  Linux
Comment (by hellik):
 Replying to [ticket:2889 marisn]:
 > Seems that wxGUI graphical modeller does not like pasting any values
 into "Add GRASS command" dialog.
 > Steps to reproduce:
 > * open Graphical Modeller
 > * click on "Add command (GRASS module) to model"
 > * paste into "Command" following example text: r.mapcalc
 expression='map=1'
 > * observe how python process is consuming 100% and wants moar! (use kill
 to get rid of it)
 > Actual pasted text does not matter - any string will do.
 > GRASS GIS 7.1.svn (r67710M)
 tested with
 GRASS version: 7.1.svn
 GRASS SVN revision: 67699
 Build date: 2016-01-29
 Build platform: x86_64-w64-mingw32
 GDAL: 1.11.3
 PROJ.4: 4.9.2
 GEOS: 3.5.0
 SQLite: 3.7.17
 Python: 2.7.5
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 not confirmed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2889#comment:1>
