[GRASS-dev] GRASS addons dependencies
Helmut Kudrnovsky
hellik at web.de
Fri Feb 5 00:56:52 PST 2016
Panagiotis Mavrogiorgos wrote
> Hi everybody,
> Some addons depend on other addons. E.g. r.lfp depends on
> r.stream.distance.
> If you try to use it while r.stream.distance is not installed, you get the
> following traceback which is not particularly helpful; especially so if
> you
> are not familiar with Python.
> Traceback (most recent call last):
>> File "/home/grassuser/.grass7/addons/scripts/r.lfp", line 111, in
> <module>
>> sys.exit(main())
>> File "/home/grassuser/.grass7/addons/scripts/r.lfp", line 43, in main
>> calculate_lfp(input, output, coords)
>> File "/home/grassuser/.grass7/addons/scripts/r.lfp", line 67, in
>> calculate_lfp
>> distance=flds)
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 392, in
>> run_command
>> ps = start_command(*args, **kwargs)
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 361, in
>> start_command
>> return Popen(args, **popts)
>> File "/usr/lib/grass70/etc/python/grass/script/core.py", line 64, in
>> __init__
>> subprocess.Popen.__init__(self, args, **kwargs)
>> File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
>> errread, errwrite)
>> File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
>> raise child_exception
>> OSError: [Errno 2] No such file or directory
> So my question is whether there is a way to define addon dependencies, and
> if there is not, what would be a sensible way to support something like
> this.
have a look here:
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.basin/r.basin.py#L82
82 # check requirements
83 def check_progs():
84 found_missing = False
85 for prog in ('r.hypso', 'r.stream.basins', 'r.stream.distance',
'r.stream.extract',
86 'r.stream.order','r.stream.snap','r.stream.stats', 'r.width.funct'):
87 if not grass.find_program(prog, '--help'):
88 found_missing = True
89 grass.warning(_("'%s' required. Please install '%s' first
using 'g.extension %s'") % (prog, prog, prog))
90 if found_missing:
91 grass.fatal(_("An ERROR occurred running r.basin"))
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-addons-dependencies-tp5248966p5249030.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
