[GRASS-dev] [GRASS GIS] #2895: Define dependencies for GRASS addons
trac at osgeo.org
Fri Feb 5 01:16:26 PST 2016
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Resolution: | Keywords: g.extension
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
Transferring Helmut Kudrnovsky's answer here:
> have a look here:
> https://trac.osgeo.org/grass/browser/grass-
addons/grass7/raster/r.basin/r.basin.py#L82
> {{{#!python
> # check requirements
> def check_progs():
> found_missing = False
> for prog in ('r.hypso', 'r.stream.basins', 'r.stream.distance',
'r.stream.extract',
> 'r.stream.order','r.stream.snap','r.stream.stats', 'r.width.funct'):
> if not grass.find_program(prog, '--help'):
> found_missing = True
> grass.warning(_("'%s' required. Please install '%s' first
using 'g.extension %s'") % (prog, prog, prog))
> if found_missing:
> grass.fatal(_("An ERROR occurred running r.basin"))
Ticket URL: <https://trac.osgeo.org/grass/ticket/2895#comment:1>
