[GRASS-dev] [GRASS GIS] #2900: The user environment settings in .grass7/bashrc are skipped
GRASS GIS trac at osgeo.org
Mon Feb 8 12:49:42 PST 2016
 Reporter:  micha    |      Owner:  grass-dev@…
     Type:  task     |     Status:  new
 Priority:  normal   |  Milestone:  7.0.4
Component:  Startup  |    Version:  7.0.3
 Keywords:  bashrc   |        CPU:  Unspecified
 Platform:  Linux    |
 The startup script /usr/bin/grass70 (in ubuntu) skips reading the user's
 bashrc file, which should be ~/.grass7/bashrc. Lines  1158-1159 in the
 script are commented out, and instead, the script reads only the older
 ~/.grass.bashrc
 Either the script should be corrected, or the documentation changed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2900>
