[GRASS-dev] i.pansharpen: brovey method parallelization glitch
Markus Neteler
neteler at osgeo.org
Tue Feb 9 08:53:52 PST 2016
when running the manual example, I observe a strange warning:
# landsat mapset
GRASS 7.1.svn (nc_spm_08_grass7): > i.pansharpen
red=lsat7_2002_30 at PERMANENT green=lsat7_2002_20 blue=lsat7_2002_10
pan=lsat7_2002_80 method=brovey output=lsat7_2002_brovey
Performing pan sharpening with hi res pan image: 14.250000
Histogram matching...
100%
100%
100%
100%
100%
100%
Calculating Brovey transformation...
100%
100%
100%
Assigning grey equalized color tables to output images...
Adding raster map <lsat7_2002_brovey_red at landsat> to group
Adding raster map <lsat7_2002_brovey_blue at landsat> to group
Adding raster map <lsat7_2002_brovey_green at landsat> to group
WARNING: No data base element files found <<--- huh?
The method=brovey uses parallelization for a r.mapcalc call.
Probably the calls of
pb.wait()
pg.wait()
pr.wait()
are incomplete?
The maps are generated anyway.
Markus
