[GRASS-dev] [GRASS GIS] #2898: GUI improvments for long list of mapsets or long mapset names (Location / Mapset selection)
trac at osgeo.org
Mon Feb 15 00:24:12 PST 2016
Mapset selection)
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: wxGUI | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: All
Comment (by sbl):
> You can already stretch the window horizontally and the boxes stretch as
well. This behavior seems good enough for me.
Yes, this seems to be no issue on a high resolution screen. On a low
resolution screen (remote desktop window (VNC)) it was impossible to
distinguish the mapsets with relatively long names / prefixes. I
understand that this is probably too much of an edge case and with a high
bandwidth I can likly get around this by requesting a connection with a
higher resolution. So, sorry for not double checking on a local
installation...
As for the filtering part: The inaccessible mapsets are already greyed
out. Those where I am not the owner cannot even be selected. In locations
with many mapsets (from different users) it would make the mapset
selection more convenient (and probably lead to less confusion among less
experienced users) if esp. the mapsets from other users, could be filtered
from the list...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2898#comment:2>
