[GRASS-dev] [GRASS GIS] #2916: configure bug (?): FORTIFY_SOURCE in CPPFLAGS breaks configure on Arch Linux
trac at osgeo.org
Tue Feb 16 03:53:52 PST 2016
Linux
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Resolution: | Keywords:
CPU: All | Platform: Linux
Comment (by msieczka):
Replying to [comment:2 neteler]:
> You would need to use autoconf-2.13 if you want to regenerate the
configure script. But I guess you don't do that anyway.
I have regenerated the configure script with autoconf-2.13 now. No
improvement: configure still fails when CPPFLAGS="-D_FORTIFY_SOURCE=2" is
set, and the resulting config.log is pretty much identical to the attached
config.log-fail.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:4>
