[GRASS-dev] [GRASS GIS] #2799: wxGUI: display toolbar size too large
trac at osgeo.org
Tue Feb 16 09:21:31 PST 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: wxGUI | Version: svn-releasebranch70
Resolution: | Keywords: wxGUI, size, toolbar, mapdisp
CPU: Unspecified | Platform: Unspecified
Comment (by veroandreo):
Replying to [comment:10 wenzeslaus]:
> r67699 (no separators in Map Display toolbar) backported in r67698
together with r67700.
> With wxPython 3.0.2.0 on Ubuntu 15.10 with Unity, all the toolbar
objects disappear one by one when the toolbar is too small for the whole
object to fit. However, the standard toolbar buttons are still accessible
through an arrow/triangle at the end of the toolbar in case they are
hidden. The look is not really good but all the functionality is
accessible including the buttons with submenu (e.g. ''Various zoom
options'') and buttons which switch with each other (e.g. ''Digitize
area/boundary/centroid''). However, this does not work for the other
widgets like the combobox/choice which is used to switch the Map Display
modes.
Under Fedora 23 (wxPython 3.0.2.0), though I can shrink the toolbar in Map
Display and I see the behaviour you describe, I can no longer shrink the
Map display window and therefore, it still overlaps with layer manager
even if it is also shrunk until limit size allowed. Same thing happens in
trunk (r67847) and release branch (r67848).
My screen is also 1366x768. I attach a png file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2799#comment:12>
