[GRASS-dev] python: get results of r.stats call into list of lists of numericals instead of list of strings
Glynn Clements
glynn at gclements.plus.com
Tue Feb 16 15:08:19 PST 2016
Moritz Lennert wrote:
> I need some help with python scripting. I'm running r.stats on two
> raster maps such as this:
> rstats_results = gscript.read_command('r.stats',
> input_=[a, b],
> flags='n1',
> separator='comma',
> quiet=True)
> results = rstats_results.splitlines()
> This gives me
> ['123,456', '456,789', '987,321']
> Does anyone know an efficient way to transform this into a list of lists
> of numbers, such as:
> [[123, 456], [456, 789], [987, 321]]
> I know I can do this as follows:
> mylist = []
> for line in results:
> mylist.append([int(line.split(',')[0]), int(line.split(',')[1])])
> But for very large raster maps this does not seem very efficient.
> Is there a way of getting the output directly as a list of lists ? Or a
> more efficient transformation ?
For a start, there's no reason to call the .split() method twice:
a, b = line.split(',')
mylist.append([int(a), int(b)])
A list comprehension might be more efficient, e.g.:
mylist = [[int(x)
for x in line.split(',')]
for line in results]
Also, rather than reading the output as a string, I'd use
pipe_command() and iterate over the file:
rstats = gscript.pipe_command('r.stats',
input_=[a, b],
flags='n1',
separator='comma',
quiet=True)
mylist = [[int(x)
for x in line.strip().split(',')]
for line in rstats.stdout]
I don't think that you'll do much better than that in Python. If it's
still too slow, try using numpy.loadtxt() (pre-processing the data
with sed if that function can't read it directly).
