[GRASS-dev] [GRASS GIS] #2917: r.mapcalc neighbour modifier uses wrong row
trac at osgeo.org
Wed Feb 17 00:27:28 PST 2016
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.4
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: r.mapcalc
CPU: Unspecified | Platform: Unspecified
Comment (by marisn):
I confirm based on the test case - issue is solved for 7.1.
Now we have only a "small" problem - it has been present in all releases
since 6.3.1 thus potentially compromising any computation based on it.
1) It must be backported to 7.x and 6.x
2) A clarification on potential impact should be provided to allow
endusers to evaluate potentially affected results of any analysis
performed with 6.3-7.0.
Replying to [comment:1 glynn]:
> Replying to [ticket:2917 marisn]:
> > Seems that in some occasions r.mapcalc neighbour modifier is using
values from wrong row.
> This appears to have been introduced in r34444 (Nov 2008), when the use
of rowio was replaced with an internal cache.
> It should be fixed by r67851.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2917#comment:2>
