[GRASS-dev] [GRASS GIS] #2916: configure bug (?): FORTIFY_SOURCE in CPPFLAGS breaks configure on Arch Linux
trac at osgeo.org
Wed Feb 17 09:06:02 PST 2016
Linux
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Resolution: | Keywords:
CPU: All | Platform: Linux
Comment (by msieczka):
Replying to [comment:6 neteler]:
> Replying to [comment:3 msieczka]:
> > Replying to [comment:2 neteler]:
> > > Replying to [ticket:2916 msieczka]:
> > > > gcc 5.3.0, make 4.1, autoconf 2.69
> > > You would need to use autoconf-2.13 if you want to regenerate the
configure script. But I guess you don't do that anyway.
> > I'd rather rely on an upstream-provided configure script, if possible.
> SVN-grass is upstream.
I'm talking from Arch Linux package perspective. In that case "upstream"
is GRASS 7.0.3 source code tarball.
> > There is no CPP package as such on Arch Linux. cpp, gcc and g++
executables come in a single GCC package here.
> I see.
> > It doesn't provide this `/lib/cpp' link.
> Seems to be a known issue in Archlinux, e.g.:
> https://bbs.archlinux.org/viewtopic.php?id=147199
> Suggestion: Try to set CPP, then configure (guessing here):
> export CPP=/usr/bin/cpp
> configure ...
Thanks. This doesn't change anything though.
I think Glynn nailed it. I'm going to have a closer look at his comments
now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:9>
