[GRASS-dev] [GRASS GIS] #2916: configure bug (?): FORTIFY_SOURCE in CPPFLAGS breaks configure on Arch Linux
trac at osgeo.org
Wed Feb 17 15:47:06 PST 2016
Linux
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Resolution: | Keywords:
CPU: All | Platform: Linux
Comment (by msieczka):
I forgot to say that the /etc/makepkg.conf contents I quoted are as per
default Arch Linux settings, and that makepkg is an official build tool
for Arch packages. I'm saying this just to clarify that I'm not making
this case up, but that it's a real issue for Arch GRASS users, in case
anybody wondered.
So far I've been removing D_FORTIFY_SOURCE from CPPFLAGS before configure
as follows, in my Arch GRASS PKGBUILD (which is an input for makepkg,
something like a Gentoo ebuild):
CPPFLAGS=`echo $CPPFLAGS | sed 's/-D_FORTIFY_SOURCE=.//g'`
If understand what you are saying, the following would be better (putting
aside your point against forcibly enabling _FORTIFY_SOURCE at all):
export CFLAGS="$CPPFLAGS $CFLAGS"
export CXXFLAGS="$CPPFLAGS $CXXFLAGS"
unset CPPFLAGS
By "better" here I mean "preserving the intended makepkg environment at
GRASS build-time".
Do you know whether all (sane) CPPFLAGS can be safely be mixed into
CXXFLAGS and CFLAGS like this?
And what do you think about scimmia's "ancient version of autoconf used"
#comment:1? I mean could using a newer autoconf version to generate the
GRASS configure script fix the problem?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:12>
