[GRASS-dev] [GRASS GIS] #2915: i.segment.hierarchical: print statements should be replaced by messages
GRASS GIS trac at osgeo.org
Fri Feb 19 08:06:38 PST 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.4
 Component:  Addons       |    Version:  unspecified
Resolution:               |   Keywords:  i.segment.hierarchical messages
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by zarch):
 Replying to [ticket:2915 mlennert]:
 > i.segment.hierarchical contains many print() statements. These should
 all be replaced by messages that can be "quieted".
 > I'm not very familiar with the message interface in pygrass: is there a
 need to create a new Messenger() for each different function & class ?
 You can get a Messenger instance using the {{{get_msgr}}} function.
 from grass.pygrass.messages import get_msgr
 def func0():
     msgr = get_msgr()
     msgr.message("Said something...")
 def func1():
     msgr = get_msgr()
     msgr.message("Said something else...")
 class MyClass(object):
     msgr = get_msgr()
     def mth(self):
         self.msgr.message("That's all!")
 func0()
 func1()
 MyClass().mth()
 or you can create a global variable
 msgr = get_msgr()
 def func0():
 def func1():
     def mth(self):
 func0()
 func1()
 MyClass().mth()
Ticket URL: <https://trac.osgeo.org/grass/ticket/2915#comment:1>
