[GRASS-dev] [GRASS GIS] #2929: v.generalize: Segmentation fault in Vect_line_intersection2()
trac at osgeo.org
Fri Feb 19 23:19:02 PST 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-releasebranch70
Keywords: v.generalize | CPU: Unspecified
Platform: Unspecified |
GRASS 7.0.3svn (nc_spm_08_grass7):~ > v.generalize input=soils_general
layer=1 type=area type=line,boundary,area method=douglas threshold=5.0
look_ahead=7 reduction=50 slide=0.5 angle_thresh=3 degree_thresh=0
closeness_thresh=0 betweeness_thresh=0 alpha=1.0 beta=1.0 iterations=1
output=soils_general_simpl
Copying features...
100%
Building topology for vector map <soils_general_simpl at user1>...
Registering primitives...
5209 primitives registered
279192 vertices registered
Building areas...
100%
1428 areas built
244 isles built
Attaching islands...
100%
Attaching centroids...
100%
Number of nodes: 2597
Number of primitives: 5209
Number of points: 0
Number of lines: 0
Number of boundaries: 3781
Number of centroids: 1428
Number of areas: 1428
Number of isles: 244
Generalization (douglas)...
Using threshold: 5 meters
Segmentation fault (core dumped)
With debugger:
GRASS 7.0.3svn (nc_spm_08_grass7):~ > gdb v.generalize
GNU gdb (GDB) Fedora 7.10.1-30.fc23
(gdb) r input=soils_general layer=1 type=area type=line,boundary,area
method=douglas threshold=5.0 look_ahead=7 reduction=50 slide=0.5
angle_thresh=3 degree_thresh=0 closeness_thresh=0 betweeness_thresh=0
alpha=1.0 beta=1.0 iterations=1 output=soils_general_simpl --o
Starting program: /home/neteler/software/grass70/dist.x86_64-pc-linux-
gnu/bin/v.generalize input=soils_general layer=1 type=area
type=line,boundary,area method=douglas threshold=5.0 look_ahead=7
reduction=50 slide=0.5 angle_thresh=3 degree_thresh=0 closeness_thresh=0
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
WARNING: Vector map <soils_general_simpl> already exists and will be
overwritten
Detaching after fork from child process 18105.
Detaching after fork from child process 18106.
Detaching after fork from child process 18107.
Detaching after fork from child process 18108.
Detaching after fork from child process 18109.
Copying features...
100%
Building areas...
100%
1428 areas built
244 isles built
100%
100%
Number of points: 0
Number of lines: 0
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7baab16 in Vect_line_intersection2 (APoints=0x62fe50,
BPoints=0x0, ABox=0x7fffffffb9e0, BBox=0x7fffffffb9e0,
ALines=0x7fffffffb9d0, BLines=0x7fffffffb9d8, nalines=0x7fffffffb9b4,
nblines=0x7fffffffb9b8, with_z=0) at intersect2.c:690
690 if (APnts->n_points < 2 || BPnts->n_points < 2) {
Backtrace
(gdb) bt full
#0 0x00007ffff7baab16 in Vect_line_intersection2 (APoints=0x62fe50,
i = 6486896
j = 0
k = 11203548
l = 0
nl = 94
last_seg = 0
seg = 32767
last = 71
n_alive_cross = 0
dist = 5.9287877500949585e-323
curdist = -nan(0xf800000004981)
last_x = 6.953355806905321e-310
last_y = 0
last_z = 3.1955138316468477e-317
x = 3.2001540961925887e-317
y = 4.6442170709077175e-322
XLines = 0xc90
Points = 0x18
Points1 = 0x7fffffffb830
Points2 = 0x0
seg1 = -18816
seg2 = 32767
vert1 = -153539728
vert2 = 32767
abbox = {N = 311049.46883242996, S = 298877.99983042991, E =
470788.96780117997, W = 452701.90679917997,
T = 9.9999999999999995e-07, B = -9.9999999999999995e-07}
bo_queue = {count = 12151696, alloc = 0, i = 0x6}
qi = {l = 18657, s = -32768, p = -18657, e = 32767}
found = 0x7fffffffb720
bo_ta = 0x2
bo_tb = 0x62b0d0
bo_t_trav = {tree = 0x0, curr_node = 0x7c00000077, up = {0x32,
0x62000000c9, 0x6, 0x0, 0x6e00000061,
0x7ffff6d92b40 <main_arena>, 0xc, 0x1eb50, 0xb984b0, 0x40f1e8,
0x3, 0x7fffffffb7f0, 0x20, 0x7ffff70db8f5,
0x7fff00000047, 0x7fffffffb810, 0xffff800000004811,
0x7fffffffb7ef, 0x0, 0x3000000003, 0x0, 0x0, 0x6e0000005b, 0x0, 0x0,
0x7c00000077, 0x6e0000005d, 0x0, 0x0, 0x7c00000077, 0x4,
0x7ffff6d92b40 <main_arena>, 0x20, 0x40f238, 0x40f210,
0x40f1e8, 0x40f1cf, 0x7ffff6a5a950 <malloc+80>, 0x40f210,
0x7ffff70db8f5, 0x7fffffffb930, 0x7ffff70bc3c6 <G__malloc+70>,
0x0, 0x20, 0xe500000000, 0x7ffff7bd00a0, 0x6e0000005b,
0xb7b6a0, 0x0, 0x7c00000077, 0x0, 0x7ffff70db8f5, 0x7fffffffb950,
0x40f238, 0x40f210, 0x7ffff6d92b40 <main_arena>, 0x20,
0x40f238, 0x40f210, 0x40f1e8, 0x40f1cf,
0x7ffff6a5a950 <malloc+80>, 0x411c34f461134c64,
0x7ffff70db8f5}, top = -17952, first = 32767}
---Type <return> to continue, or q <return> to quit---
same = 0
#1 0x000000000040e866 in check_topo (Out=0x7fffffffc3e0, line=1,
APoints=0xb7b9a0, Points=0x62fe50, Cats=0x62fe80) at misc.c:212
i = 1082222060
j = -1732403045
intersect = 1076144781
newline = 0
left_old = 1092369170
right_old = -698033653
left_new = 1091750490
right_new = 0
box = {N = 311049.46883142996, S = 298877.99983142992, E =
470788.96780017996, W = 452701.90680017998, T = 0, B = 0}
BPoints = 0xb7b670
List = 0xb7b6a0
AXLines = 0x0
BXLines = 0x0
naxlines = 0
nbxlines = 0
#2 0x000000000040a55b in main (argc=19, argv=0x7fffffffd4e8) at
main.c:559
after = 0
not_modified_boundaries = 0
n_oversimplified = 0
APoints = 0xb7b9a0
In = {format = 0, temporary = 0, dblnk = 0x87fe50, plus = {version
= {topo = {major = 5, minor = 1, back_major = 5,
back_minor = 1}, spidx = {major = 5, minor = 1, back_major
= 5, back_minor = 1}, cidx = {major = 5, minor = 0,
back_major = 5, back_minor = 0}}, with_z = 0, spidx_with_z
= 0, off_t_size = 4, head_size = 142,
spidx_head_size = 113, cidx_head_size = 9, release_support =
0, port = {byte_order = 0, off_t_size = 0,
dbl_cnvrt = "\000\001\002\003\004\005\006\a", flt_cnvrt =
"\000\001\002\003", lng_cnvrt = "\000\001\002\003",
int_cnvrt = "\000\001\002\003", shrt_cnvrt = "\000\001",
off_t_cnvrt = "\000\001\002\003\004\005\006\a",
dbl_quick = 1, flt_quick = 1, lng_quick = 1, int_quick = 1,
shrt_quick = 1, off_t_quick = 1}, spidx_port = {
byte_order = 0, off_t_size = 4, dbl_cnvrt =
"\000\001\002\003\004\005\006\a", flt_cnvrt = "\000\001\002\003",
lng_cnvrt = "\000\001\002\003", int_cnvrt =
off_t_cnvrt = "\000\001\002\003\004\005\006\a", dbl_quick =
shrt_quick = 1, off_t_quick = 1}, cidx_port = {byte_order =
0, off_t_size = 0,
shrt_quick = 1, off_t_quick = 1}, mode = 0, built = 4,
box = {N = 318117.43783143, S = 10303.983831430087, E =
930323.81280017993, W = 123971.19480017992, T = 0, B = 0},
Node = 0x634140, Line = 0x68a540, Area = 0x6e5e60, Isle =
0x712230, n_plines = 0, n_llines = 0, n_blines = 3781,
n_clines = 1428, n_flines = 0, n_klines = 0, n_vfaces = 0,
n_hfaces = 0, n_nodes = 2597, n_edges = 0, n_lines = 5209,
n_areas = 1428, n_isles = 244, n_faces = 0, n_volumes = 0,
n_holes = 0, alloc_nodes = 2597, alloc_edges = 0,
alloc_lines = 5209, alloc_areas = 1428, alloc_isles = 244,
alloc_faces = 0, alloc_volumes = 0, alloc_holes = 0,
Node_offset = 142, Edge_offset = 0, Line_offset = 112578,
Area_offset = 204831, Isle_offset = 250475, Volume_offset = 0,
Hole_offset = 0, Spidx_built = 1, Spidx_new = 0, Spidx_file =
1, spidx_fp = {file = 0x716c60, start = 0x0,
current = 0x0, end = 0x0, size = 0, alloc = 0, loaded = 0},
Node_spidx_offset = 228117, Line_spidx_offset = 669845,
Area_spidx_offset = 794557, Isle_spidx_offset = 815977,
Face_spidx_offset = 0, Volume_spidx_offset = 0,
Hole_spidx_offset = 0, Node_spidx = 0x6301f0, Line_spidx =
0x78d260, Area_spidx = 0x806750, Isle_spidx = 0x87fc40,
Face_spidx = 0x0, Volume_spidx = 0x0, Hole_spidx = 0x0,
update_cidx = 0, n_cidx = 2, a_cidx = 5, cidx = 0x6337f0,
cidx_up_to_date = 1, coor_size = 15959831, coor_mtime = 0,
uplist = {do_uplist = 0, uplines = 0x0, uplines_offset = 0x0,
alloc_uplines = 0, n_uplines = 0, upnodes = 0x0,
alloc_upnodes = 0, n_upnodes = 0}}, open = 1428335138, mode = 0,
level = 2, head_only = 0, support_updated = 0, name = 0x6339e0
"soils_general", mapset = 0x633aa0 "PERMANENT",
location = 0x633ac0 "nc_spm_08_grass7", gisdbase = 0x633ae0
"/home/neteler/grassdata", next_line = 1, constraint = {
region_flag = 0, box = {N = 0, S = 0, E = 0, W = 0, T = 0, B =
0}, type_flag = 0, type = 0, field_flag = 0, field = 0},
proj = 0, hist_fp = 0x90cfb0, dgraph = {line_type = 0, graph_s =
{iErrno = 0, Version = 0 '\000', Endian = 0 '\000',
NodeAttrSize = 0, EdgeAttrSize = 0, aOpaqueSet = {0 <repeats
16 times>}, cNode = 0, cHead = 0, cTail = 0, cAlone = 0,
cEdge = 0, nnCost = 0, Flags = 0, nFamily = 0, nOptions = 0,
pNodeTree = 0x0, pEdgeTree = 0x0, pNodeBuffer = 0x0,
iNodeBuffer = 0, pEdgeBuffer = 0x0, iEdgeBuffer = 0,
edgePrioritizer = {cEdge = 0, iEdge = 0, pEdgePri32Item = 0x0,
pvAVL = 0x0}, nodePrioritizer = {pvAVL = 0x0}}, spCache =
{nStartNode = 0, NodeHeap = {index = 0, count = 0,
block = 0, pnode = 0x0}, pvVisited = 0x0, pvPredist =
0x0}, edge_fcosts = 0x0, edge_bcosts = 0x0, node_costs = 0x0,
cost_multip = 0}, head = {organization = 0x633b00 "NC OneMap",
date = 0x633b20 "", user_name = 0x633b40 "helena",
map_name = 0x633a40 "North Carolina general soils map (polygon
map)", source_date = 0x633b80 "Mon Nov 6 15:46:05 2006",
orig_scale = 1, comment = 0x633bb0 "", proj = 99, plani_zone =
0, digit_thresh = 0, coor_version = {major = 5,
minor = 1, back_major = 5, back_minor = 1}, with_z = 0, size
= 15959831, head_size = 14, port = {byte_order = 0,
off_t_size = 0, dbl_cnvrt =
shrt_quick = 1, off_t_quick = 1}, last_offset = 15959802,
recycle = 0x0}, dig_fp = {file = 0x8f90d0, start = 0x0,
fInfo = {i = 0, ogr = {driver_name = 0x0, dsn = 0x0,
layer_name = 0x0, driver = 0x0, ds = 0x0, layer = 0x0,
dbdriver = 0x0, dsn_options = 0x0, layer_options = 0x0,
cache = {lines = 0x0, lines_types = 0x0, lines_cats = 0x0,
lines_alloc = 0, lines_num = 0, lines_next = 0, fid = 0,
sf_type = SF_GEOMETRY, ctype = 0}, feature_cache = 0x0,
offset = {array = 0x0, array_num = 0, array_alloc = 0},
next_line = 0}, pg = {conninfo = 0x0, db_name = 0x0,
schema_name = 0x0, table_name = 0x0, fid_column = 0x0,
geom_column = 0x0, feature_type = SF_GEOMETRY, coor_dim = 0,
srid = 0, dbdriver = 0x0, fi = 0x0, inTransaction = 0,
conn = 0x0, res = 0x0, cursor_name = 0x0, cursor_fid = 0,
next_line = 0, cache = {lines = 0x0, lines_types = 0x0,
lines_cats = 0x0, lines_alloc = 0, lines_num = 0,
lines_next = 0, fid = 0, sf_type = SF_GEOMETRY, ctype = 0},
topogeom_column = 0x0, toposchema_name = 0x0,
toposchema_id = 0, topo_geo_only = 0}}, site_att = 0x0,
n_site_att = 0, n_site_dbl = 0, n_site_str = 0}
Out = {format = 0, temporary = 0, dblnk = 0x914230, plus =
{version = {topo = {major = 0, minor = 0, back_major = 0,
back_minor = 0}, spidx = {major = 0, minor = 0, back_major
= 0, back_minor = 0}, cidx = {major = 0, minor = 0,
back_major = 0, back_minor = 0}}, with_z = 0, spidx_with_z
= 0, off_t_size = 0, head_size = 0, spidx_head_size = 0,
cidx_head_size = 0, release_support = 0, port = {byte_order =
0, off_t_size = 0,
dbl_cnvrt = "\000\000\000\000\000\000\000", flt_cnvrt =
"\000\000\000", lng_cnvrt = "\000\000\000",
int_cnvrt = "\000\000\000", shrt_cnvrt = "\000", off_t_cnvrt
= "\000\000\000\000\000\000\000", dbl_quick = 0,
flt_quick = 0, lng_quick = 0, int_quick = 0, shrt_quick = 0,
off_t_quick = 0}, spidx_port = {byte_order = 0,
off_t_size = 0, dbl_cnvrt = "\000\000\000\000\000\000\000",
flt_cnvrt = "\000\000\000", lng_cnvrt = "\000\000\000",
off_t_quick = 0}, cidx_port = {byte_order = 0,
off_t_quick = 0}, mode = 1, built = 4, box = {
Node = 0xa4c050, Line = 0xaf0020, Area = 0xb4ce60, Isle =
0xb016c0, n_plines = 0, n_llines = 0, n_blines = 3781,
n_holes = 0, alloc_nodes = 3000, alloc_edges = 0,
alloc_lines = 6000, alloc_areas = 2000, alloc_isles = 1000,
Node_offset = 0, Edge_offset = 0, Line_offset = 0, Area_offset
= 0, Isle_offset = 0, Volume_offset = 0, Hole_offset = 0,
Spidx_built = 1, Spidx_new = 1, Spidx_file = 0, spidx_fp =
{file = 0x0, start = 0x0, current = 0x0, end = 0x0, size = 0,
alloc = 0, loaded = 0}, Node_spidx_offset = 0,
Line_spidx_offset = 0, Area_spidx_offset = 0, Isle_spidx_offset = 0,
Hole_spidx_offset = 0, Node_spidx = 0x9110d0, Line_spidx = 0x911c40,
Area_spidx = 0x912820, Isle_spidx = 0x913430, Face_spidx =
0x0, Volume_spidx = 0x0, Hole_spidx = 0x0, update_cidx = 0,
n_cidx = 2, a_cidx = 5, cidx = 0x914040, cidx_up_to_date = 1,
coor_size = 0, coor_mtime = 0, uplist = {do_uplist = 0,
uplines = 0x0, uplines_offset = 0x0, alloc_uplines = 0,
n_uplines = 0, upnodes = 0x0, alloc_upnodes = 0,
n_upnodes = 0}}, open = 1428335138, mode = 2, level = 2,
head_only = 0, support_updated = 1,
name = 0x90cb50 "soils_general_simpl", mapset = 0x90cb70
"user1", location = 0x90cb90 "nc_spm_08_grass7",
gisdbase = 0x90cbb0 "/home/neteler/grassdata", next_line = 0,
constraint = {region_flag = 0, box = {N = 0, S = 0, E = 0,
W = 0, T = 0, B = 0}, type_flag = 0, type = 0, field_flag =
0, field = 0}, proj = 0, hist_fp = 0x910bb0, dgraph = {
line_type = 0, graph_s = {iErrno = 0, Version = 0 '\000',
Endian = 0 '\000', NodeAttrSize = 0, EdgeAttrSize = 0,
aOpaqueSet = {0 <repeats 16 times>}, cNode = 0, cHead = 0,
cTail = 0, cAlone = 0, cEdge = 0, nnCost = 0, Flags = 0,
nFamily = 0, nOptions = 0, pNodeTree = 0x0, pEdgeTree = 0x0,
pNodeBuffer = 0x0, iNodeBuffer = 0, pEdgeBuffer = 0x0,
iEdgeBuffer = 0, edgePrioritizer = {cEdge = 0, iEdge = 0,
pEdgePri32Item = 0x0, pvAVL = 0x0}, nodePrioritizer = {
pvAVL = 0x0}}, spCache = {nStartNode = 0, NodeHeap =
{index = 0, count = 0, block = 0, pnode = 0x0},
pvVisited = 0x0, pvPredist = 0x0}, edge_fcosts = 0x0,
edge_bcosts = 0x0, node_costs = 0x0, cost_multip = 0}, head = {
organization = 0x633a20 "NC OneMap", date = 0x90caa0 "",
user_name = 0x90cac0 "helena",
map_name = 0x9142c0 "North Carolina general soils map (polygon
map)", source_date = 0x90cb00 "Mon Nov 6 15:46:05 2006",
orig_scale = 1, comment = 0x90cb30 "", proj = 99, plani_zone =
= 0, head_size = 18, port = {byte_order = 0,
shrt_quick = 1, off_t_quick = 1}, last_offset = 4469991,
recycle = 0x0}, dig_fp = {file = 0x62fb70, start = 0x0,
Error = {format = 1809973248, temporary = -4163, dblnk =
0x7ffff6d91b80, plus = {version = {topo = {major = -134471680,
minor = 32767, back_major = -136363730, back_minor =
32767}, spidx = {major = 0, minor = 0, back_major = 6,
back_minor = 0}, cidx = {major = -134492104, minor =
32767, back_major = -136407415, back_minor = 32767}},
with_z = 1, spidx_with_z = 32767, off_t_size = -134485304,
head_size = 140737488341408, spidx_head_size = -1759510528,
cidx_head_size = 140737488342560, release_support =
-136407949, port = {byte_order = 32767, off_t_size = 1,
dbl_cnvrt = "\377\177\000\000\370\345\373", <incomplete
sequence \367>, flt_cnvrt = "\377\177\000",
lng_cnvrt = "\020\314\377\377", int_cnvrt = "\377\177\000",
shrt_cnvrt = "\004",
off_t_cnvrt = "\000\000\000\000\000\000", <incomplete
sequence \316>, dbl_quick = 32767, flt_quick = -136407949,
lng_quick = 32767, int_quick = 1, shrt_quick = 32767,
off_t_quick = -134227560}, spidx_port = {byte_order = 32767,
off_t_size = -13248, dbl_cnvrt =
"\377\177\000\000\002\000\000", flt_cnvrt = "\000\000\000",
lng_cnvrt = "0\320\377\377", int_cnvrt = "\377\177\000",
shrt_cnvrt = "s\224",
off_t_cnvrt = "\336\367\377\177\000\000\001", dbl_quick =
32767, flt_quick = -134488064, lng_quick = 32767,
int_quick = -13200, shrt_quick = 32767, off_t_quick =
-1740636160}, cidx_port = {byte_order = -1, off_t_size = -12144,
dbl_cnvrt = "\377\177\000\000s\224\336", <incomplete
lng_cnvrt = "\001\000\000", int_cnvrt = "\377\177\000",
shrt_cnvrt = <incomplete sequence \367>,
off_t_cnvrt = "\373\367\377\177\000\000\240", <incomplete
sequence \314>, dbl_quick = 32767, flt_quick = 4,
lng_quick = 0, int_quick = -12144, shrt_quick = 32767,
off_t_quick = -136407949}, mode = 32767, built = 1, box = {
N = 6.9533491634441538e-310, S = 6.9533558071875807e-310, E
= -nan(0xfffff99000000), W = 6.9533558072468686e-310,
T = 6.9533490683868623e-310, B = 6.9531436082559572e-310},
Node = 0x7ffff7fc0ac0, Line = 0x7fffffffcd00,
Area = 0xffffffff99600000, Isle = 0x7fffffffd180, n_plines =
-136407949, n_llines = 32767, n_blines = 1,
n_clines = 32767, n_flines = -134478496, n_klines = 32767,
n_vfaces = -13008, n_hfaces = 32767, n_nodes = -1715470336,
n_edges = -1, n_lines = -11904, n_areas = 32767, n_isles =
-136407949, n_faces = 32767, n_volumes = 1, n_holes = 32767,
alloc_nodes = -134479872, alloc_edges = 32767, alloc_lines =
-12960, alloc_areas = 32767, alloc_isles = -1709178880,
alloc_faces = -1, alloc_volumes = -11904, alloc_holes = 32767,
Node_offset = 140737351947379,
Edge_offset = 140733193388033, Line_offset = 140737353882024,
Area_offset = 140737488342416, Isle_offset = -1702887424,
Volume_offset = 140737488343424, Hole_offset =
140737351947379, Spidx_built = 1, Spidx_new = 32767,
Spidx_file = -134474536, spidx_fp = {file = 0x7fffffffcdc0,
start = 0xffffffff9ae00000 <error: Cannot access memory at
address 0xffffffff9ae00000>,
current = 0x7fffffffd180 "\030\322\377\377\377\177",
end = 0x7ffff7de9473 <_dl_map_object_deps+595>
"H\213M\230H\205\311\017\205\325\003", size = 17179869185,
alloc = 140737353879552, loaded = -12816}, Node_spidx_offset
= 25769803778, Line_spidx_offset = 140737488343424,
Area_spidx_offset = 140737351947379, Isle_spidx_offset =
60129542145, Face_spidx_offset = 140737353886320,
Volume_spidx_offset = 140737488342560, Hole_spidx_offset =
6917674184651309252, Node_spidx = 0x7fffffffd180,
Line_spidx = 0x7ffff7de9473 <_dl_map_object_deps+595>,
Area_spidx = 0x48320e2000000001,
Isle_spidx = 0x7ffff7de5374 <check_match.isra+228>, Face_spidx
= 0x7fffffffce50, Volume_spidx = 0x7ffff7fc2000,
Hole_spidx = 0x7ffff69d9810, update_cidx = 873, n_cidx = 0,
a_cidx = -134470864,
cidx = 0x7ffff7de5c01 <do_lookup_x+2081>, cidx_up_to_date =
873, coor_size = 140737330970368,
coor_mtime = 140737353884384, uplist = {do_uplist =
-134470864, uplines = 0x7fffffffcf78,
uplines_offset = 0x7ffff7de5374 <check_match.isra+228>,
alloc_uplines = -134474536, n_uplines = 32767,
upnodes = 0x7ffff7ffe6e0, alloc_upnodes = -134241904,
n_upnodes = 32767}}, open = 5, mode = 0, level = -134223344,
head_only = 32767, support_updated = -136422399, name = 0x5
<error: Cannot access memory at address 0x5>,
mapset = 0x7ffff7ffa2b0 "", location = 0x7ffff7ffe9c0
"\370\346\371\367\377\177",
gisdbase = 0x7ffff7ffea10 "\016\243\377\367\377\177", next_line
= -12328, constraint = {region_flag = -136424588, box = {
N = 6.953349156807864e-310, S = 6.9533491640512617e-310, E =
6.9533480289714083e-310, W = 2.0009658656570485e-321,
T = 6.9533491640915774e-310, B = 6.9533490675647864e-310},
type_flag = 405, type = 0, field_flag = -134471680,
field = 32767}, proj = -157439188, hist_fp = 0x830, dgraph =
{line_type = -134470864, graph_s = {iErrno = -136422399,
Version = 255 '\377', Endian = 127 '\177', NodeAttrSize =
2096, EdgeAttrSize = 140737330970368, aOpaqueSet = {
140737353884384, 140737353884464, 140737488343144,
140737488343140, 140737353869608, 140737286732676,
140737330970368, 140737330916704, 140737286598040,
140737488343144, 479434334, 7491161, 140733193388062,
140737488343360, 140737488343140, 140737488343344}, cNode
= 140737353737040, cHead = 140737351930740, cTail = 105,
cAlone = 140737353883648, cEdge = 140737330916652, nnCost =
2224, Flags = 140737353884464, nFamily = 140737351932929,
nOptions = 2224, pNodeTree = 0x7ffff69e7f00, pEdgeTree =
0x7ffff7fc22e0,
pNodeBuffer = 0x7ffff7fc2330 "j؞\366\377\177", iNodeBuffer =
140737488343352, pEdgeBuffer = 0x7fffffffd134 "",
iEdgeBuffer = 140737330912272, edgePrioritizer = {cEdge =
-201622395, iEdge = 32767, pEdgePri32Item = 0x7ffff69e7f00,
pvAVL = 0x7ffff69dad60}, nodePrioritizer = {pvAVL =
0x7ffff3f96a20}}, spCache = {nStartNode = 140737488343352,
NodeHeap = {index = 2090266759, count = 32660418, block =
140733193388039, pnode = 0x7fffffffd210},
pvVisited = 0x7fffffffd134, pvPredist = 0x7fffffffd200},
edge_fcosts = 0x7ffff7f9e350, edge_bcosts = 0x7fff00000000,
node_costs = 0x69, cost_multip = -136424588}, head = {
organization = 0xf3f99810 <error: Cannot access memory at
address 0xf3f99810>, date = 0x7ffff7fc19a8 "",
user_name = 0x7ffff4fc32c0
"\017\343\262Ϥ\370\206^)#\350(\320\020\361\273Uzn1ٮ\332\067I\002\024\017\272\035\355\017(u\005ԯ0\232u\246\333˭\371d\351N\263\035\360\264\377\301V\257\002J\356\333F8
\250m\277a:\254\016\301\022\305\316`\177\322\371\377ٍ\323xC\b\357\a_\001P\\\336\071\221N\031u\017:\352}\203\v8\374\361[\036\320\311\037[\032)\177\347\atS\311M\"-\377\332\360\022o\333G)\f\322\017+\201\177\314\375\305\036\254\ao\244Pd#\033\357\242\071\321\333\365/Eл\204\066\227\003'Du\371\240\367L\350L\320p\231\031B{[p'\260\230u\221\323*(\351P\325
건r\030", <incomplete sequence \374\200\255>...,
map_name = 0x3950 <error: Cannot access memory at address
0x3950>, source_date = 0x7ffff7fc1cd8 "\234L\021\365\377\177",
orig_scale = 140737351932929, comment = 0x3950 <error: Cannot
access memory at address 0x3950>, proj = -184229288,
plani_zone = 32767, digit_thresh = 6.9533491640073886e-310,
coor_version = {major = -134472488, minor = 32767,
back_major = -11752, back_minor = 32767}, with_z = -11756,
size = 140737488343592, head_size = 140737304652546,
port = {byte_order = -184229288, off_t_size = 32767, dbl_cnvrt
= "\350\253\374\364\377\177\000",
flt_cnvrt = "h\v", <incomplete sequence \365>, lng_cnvrt =
"\377\177\000", int_cnvrt = "\030\322\377\377",
shrt_cnvrt = "\377\177", off_t_cnvrt =
"\000\000\016\343\262\317\000", dbl_quick = 54446988, flt_quick = 0,
lng_quick = 14, int_quick = 0, shrt_quick = -11536,
off_t_quick = 32767}, last_offset = 140737488343572,
recycle = 0x7fffffffd2e0}, dig_fp = {file = 0x7ffff7f9e350,
start = 0x7fff00000000 <error: Cannot access memory at address
0x7fff00000000>,
current = 0x69 <error: Cannot access memory at address 0x69>,
end = 0x7fff00000000 <error: Cannot access memory at address
0x7fff00000000>, size = 105, alloc = 0, loaded = 1},
fInfo = {i = -134472448, ogr = {driver_name = 0x7fffffffd380
"]", dsn = 0x7fffffffd3a8 "h\v\002\365\377\177",
layer_name = 0x0, driver = 0x7ffff7fc19a8, ds = 0x0, layer =
0x7ffff7de6050 <_dl_lookup_symbol_x+320>, dbdriver = 0xd,
dsn_options = 0x0, layer_options = 0x1, cache = {lines =
0x0, lines_types = 0x1, lines_cats = 0x7ffff7fc19a8,
lines_alloc = 1, lines_num = 0, lines_next = -134473304,
fid = 73, sf_type = SF_GEOMETRY, ctype = 0},
feature_cache = 0x7ffff7fc1d00, offset = {array =
0x7fffffffd2f0, array_num = -134472448, array_alloc = 1},
next_line = -11552}, pg = {conninfo = 0xcfb2e30e <error:
Cannot access memory at address 0xcfb2e30e>,
db_name = 0x7ffff50ceb02
"_ZN20OGRXPlaneEnumerationC1EPKcPK19sEnumerationElementi",
schema_name = 0xffffffff <error: Cannot access memory at
address 0xffffffff>,
table_name = 0x7ffff505d8cb "__cxa_atexit", fid_column =
0x7ffff5020b68 "\252\b\b", geom_column = 0x7ffff7fc19a8 "",
feature_type = 4137548136, coor_dim = 32767, srid =
-134471680, dbdriver = 0x410, fi = 0x7fffffffd390,
inTransaction = 64, conn = 0x7fffffffd3a0, res = 0x410,
cursor_name = 0x7fffffffd37f "", cursor_fid = 2,
next_line = 0, cache = {lines = 0x7fffffffd3c0, lines_types
= 0xffff800000002c61, lines_cats = 0x7fffffffd39f,
lines_alloc = 16, lines_num = 0, lines_next = 66, fid = 2,
sf_type = SF_GEOMETRY, ctype = 0}, offset = {
array = 0x6e0000005d, array_num = 0, array_alloc = 0},
toposchema_name = 0x7c00000077 <error: Cannot access memory
at address 0x7c00000077>, toposchema_id = 1,
topo_geo_only = 0}}, site_att = 0x7ffff5020b68, n_site_att =
-168946992, n_site_dbl = 32767, n_site_str = 19}
Points = 0x62fe50
Cats = 0x62fe80
i = 1
type = 4
iter = 1
module = 0x7ffff72e67a8 <state+40>
map_in = 0x7ffff72e6808 <state+136>
map_out = 0x62d860
error_out = 0x62d920
thresh_opt = 0x62daa0
method_opt = 0x62d9e0
look_ahead_opt = 0x62e120
iterations_opt = 0x62e760
cat_opt = 0x62e820
alpha_opt = 0x62e5e0
beta_opt = 0x62e6a0
type_opt = 0x62d7a0
field_opt = 0x62d6e0
where_opt = 0x62e8e0
reduction_opt = 0x62e1c0
slide_opt = 0x62e260
angle_thresh_opt = 0x62e300
degree_thresh_opt = 0x62e3a0
closeness_thresh_opt = 0x62e460
betweeness_thresh_opt = 0x62e520
notab_flag = 0x62e9c0
loop_support_flag = 0x7ffff72e67d8 <state+88>
with_z = 0
total_input = 365
total_output = 0
thresh = 5
alpha = 1
beta = 1
reduction = 50
slide = 0.5
angle_thresh = 3
degree_thresh = 0
closeness_thresh = 0
betweeness_thresh = 0
method = 0
look_ahead = 7
iterations = 1
loop_support = 1
layer = 1
n_lines = 5209
simplification = 1
mask_type = 70
cat_list = 0x0
s = 0x62efa0 "douglas"
descriptions = 0x62dbe0 "douglas;Douglas-Peucker
Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction
parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction
Algorithm eliminates points close t"...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2929>
