[GRASS-dev] [GRASS GIS] #2919: r.stream.extract error
trac at osgeo.org
Sat Feb 20 06:14:17 PST 2016
Reporter: PitStop | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Addons | Version: 7.0.3
Resolution: | Keywords: r.stream.extract
CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:1 neteler]:
> I just tried on Linux, no such issue:
> g.region raster=elev_srtm_30m
> r.watershed elevation=elev_srtm_30m at PERMANENT threshold=1000
> accumulation=accu drainage=drain basin=basin
> r.stream.extract elevation=elev_srtm_30m at PERMANENT
accumulation=accu at user1 \
> threshold=1000 stream_raster=stream_r stream_vector=stream_v
> No errors occured.
> g.version -g
> version=7.0.4svn
> date=2016
> revision=67880M
> build_date=2016-01-20
> build_platform=x86_64-pc-linux-gnu
> You marked it as "addon" while it is part of core GRASS 7. Is it
possible that you are using a leftover Addon version of r.stream.extract?
Confirmed here in winGRASS. the default value of d8cut seems not to be
recognized by parser in winGRASS again. see the mentioned ML entry.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2919#comment:2>
