[GRASS-dev] r.bioclim output integer maps
Markus Metz
markus.metz.giswork at gmail.com
Sun Feb 21 03:20:31 PST 2016
On Wed, Feb 10, 2016 at 2:39 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> On Wed, Feb 10, 2016 at 1:16 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Feb 10, 2016 12:03 PM, "Paulo van Breugel" <p.vanbreugel at gmail.com>
>> wrote:
>> > On Wed, Feb 10, 2016 at 10:26 AM, Markus Neteler <neteler at osgeo.org>
>> > wrote:
>> >> I guess for the compatibility with WORLDCLIM (have added that, too).
>> >> The other Markus will know better :-)
>> > I still think it is really preferable to not round these numbers, but
>> > leave that to the user (perhaps include it as an option though). But in any
>> > case, the text you added makes things more explicit / clear, which is most
>> > important.
>> Python patches are welcome!
> I could give that a try (wasn't difficult if I remember well), but I rather
> first hear from Markus (the other ;-) whether he thinks it is something that
> could/should be changed
It could be changed, but I am not sure if it is worth the trouble.
When I wrote the module, I used bioclim from worldclim as test suite
which also uses integer. That means when using worldclim as input, the
default settings produce output identical to worldclim's bioclim maps.
Instead of leaving the rounding to the user, you could also leave the
conversion to fp to the user. I prefer to have rounding to integer
because 1) users will not get the false impression of high accuracy
with floating point values, 2) it saves a lot of disk space.
Markus M
